AAAAAAAAAAAAAAAAAAARGHHH!!
GadgetBoy
i worked for Honda for 10 years building cars and left due to where they are going with what they build now and in the future the old red top is doomed in europe ...
( also the build quality is going to shot ...my old fiat lumps would rev just as free as a honda sit all day at 8000rpm and bounce off 10000rpm
well that went off topic a bit
for me the b18 is the best all round engine I have ever had the pleasure to drive, I know the d series used pgmfi which was a complex ecu system, was this to make up for the poor inlets??
tempted to turbo the twin cam then? nudge nudge, just so I see what it goes like
Hand painted black niva 96 1.7I aka the problem child!
96 spec Integra type R aka the rice rocket!
baxter
So Honda engines are "complete shite" because their inlet manifolds are not 100%.GadgetBoy wrote:The design and implementation of the inlet tracts is truly woeful in terms of airflow management and rough as .... in actual manufacture. If Honda had done the inlet system correctly they would be great engines. You should read what Guy Croft thinks of them.
I'm guessing you're never been in quick vtec then.
Even with the apparently crappy inlet manifold they blow away any other equivalent NA car I've driven. And as Simon says they're completely tractable while doing it.
And I wouldn't be too sure about the alleged flaw in the manifold design; I don't know a lot about vtecs but iirc many of the after-market inlet manifolds actually loose power and the factory one is ok for anything up to serious internal mods.
Honda were experts in flow: The ZC engine (pre-vtec) in my CRX has such great flow from the factory that many engine tuners get less power by dicking around with the ports. It's generally accepted the the flow only needs work on very highly modified ones.
And I've thrashed the crap out of several Honda ZC motors (ie in motorsport) and am yet to kill one.
If you've got hesitation something's not 100%. If the carb's not 100%, the engine's never going to give its best. I had similar problems with a Saab, in hind sight I should have just rebuilt the darn carb rather than keeping swapping out for different, but equally knackered ones!
What you're saying there regarding stuttering after long periods of high revs, sounds almost like you might be suffering fuel starvation?
I'd either give the carb you've got a service, and give everything else a good service while you're at it before making any judgements.
Imagine the carb would need to be re-tuned for the new engine as well, especially if it's been set up to compensate for the wear on the old one.
baxter
Weber?SimonAllen wrote: Will a rebuild kit solve the butterfly having play in the shaft?
No sadly, it'll need to be machined and bushed or oversize shafts iirc; and it's a specialist job (someone here did a neat looking job with a drill and the result was no where near accurate enough).
There's some neat looking little bearing inserts that used to be available.
Worn shafts can give endless problems, and are why I'm back on a VAZ carb as all my old Webers have the problem to some extent.
i was always told to avoid HIF`s and use any of the older types with float chamber on the side..which i did on my fiats ...only problem i had was freezing up at about 7500 rpm ish , i bought some fuel additive and that cured it along with a x19 carb fan with thermostat as when it got hot it vapourised .....you can buy a kit for a su to fit on a ford cross flow so would imagine you could cobble that to fit a lada
