1980 Volkswagen T25 Camper Van Restoration Project
GadgetBoy
Post by GadgetBoy » Sun Jul 17, 2011 9:39 pm
If the stud has snapped flush with the crankcase don't waste your time with stud extractors.
The studs are hardened and you'll need Kryptonite drill bits.
Look up spark erosion on Google.
Post by Zelandeth » Sun Jul 17, 2011 9:47 pm
Hmm, plug being the culprit sounds far too optimistic...Guess the best test there would be to switch it for one from the opposite side and see if the noise follows the plug...
I suspect if the stud has snapped flush with the crank case it will be a case of getting the engine to someone who knows their stuff and going "Heeeeeeelp!" or finding a replacement power unit...After all, the CT *is* just a little on the gutless side for a vehicle this size at 50bhp even when working right...
GadgetBoy
Post by GadgetBoy » Sun Jul 17, 2011 9:55 pm
Plugs.
1. It's more common than you think.
2. What age is that plug?
Post by Zelandeth » Sun Jul 17, 2011 10:25 pm
Hmm, what age is it? Not a clue...but I'm going to vouch for "ancient" I think!
Nobody locally seems to have suitable plugs, I've already tried to get replacements, so will need to get some from online suppliers...I'm old fashioned though and far prefer going into a shop for things like this.
Video below exhibits the "ticking" on acceleration - sound is pretty much exactly what you'd expect for a blowing exhaust manifold gasket I'd say albeit quieter (though that appears to be perfect in this case).
[youtube]http://www.youtube.com/watch?v=1w4y1APGjaI[/youtube]
Plug problem definitely would be preferred though.
Hoodoo
No rank
Post by Hoodoo » Wed Aug 17, 2011 5:58 pm
Programme tonight at 9pm on Quest (Freeview 38 ) Chap restoring a VW Camper!!!!
Regards,
Hoodoo
'03 Niva 1.7si
Buckley, North Wales.
nitro_warrior
Gold
Gold
Post by nitro_warrior » Thu Aug 18, 2011 9:58 am
Zelandeth wrote: Nobody locally seems to have suitable plugs, I've already tried to get replacements, so will need to get some from online suppliers...I'm old fashioned though and far prefer going into a shop for things like this.
Neil isn't local for Lada spares!
Give GSF car parts a shot, they're pretty good for old dub stuff.
http://www.gsfcarparts.com/
2 x Fiat Panda 4x4 999cc
VW Type 3 Fast back
Chrysler Voyager
Edinburgh
Post by Zelandeth » Thu Aug 18, 2011 7:39 pm
Was out unfortunately when that show was on - will keep my eyes out for a repeat though - even though that does mean actually unearthing the TV. Don't think it's been on since about this time last year...
Not kidding when I say unearth either...I can actually *see* the TV...the freeview box however is somewhere under that pile to the left of it...
I suffer from a chronic lack of storage space in this flat - so any flat area where there's room for stuff to be stacked where it's not in the way tends to end up looking like this over a period of a few months - until I have a proper clear up and toss most of it in the bin...at which point I immediately need whatever it was that I just threw out.
Post by Zelandeth » Tue Aug 23, 2011 10:05 pm
Naturally my intention to order the inner sill for the van this month has fallen apart...the tax on the 306 is due at the end of the month...D'OH!
Still...at least I've found someone who stocks them in the UK, as part enquiries being sent via VW's own classic parts finder were going unanswered. Cost isn't that much higher either really when you factor in that VW charge for shipping.
Link
It's worth a few quid extra to be ordering from a company in the UK who speak English and can answer questions about the part I think!
*sigh* Another month down the drain. Going to be October before I even get started on the real reconstruction again...Argh!
Post by excossack » Wed Aug 24, 2011 7:07 am
Is that an Acorn Monitor I spotted there?
Post by Zelandeth » Tue Nov 01, 2011 7:34 pm
John,
Yes it is...It's actually a Philips RGB PAL monitor which appeared with various badges on it, I've seen Amiga, Acorn and Amstrad labels on them - also works a cracking little TV connected to a freeview box...which is what I use it for!
Had a thought today. One of those random thoughts which are always dangerous when I have them...
Basically, I'm still grumbling about having (and unable to currently afford) to spend £120 odd on sills (VW themselves have repeatedly failed to respond to me, that's the price from VW Heritage). When I suddenly had a bit of a Eureka moment and came up with a cheaper and not much more complicated possible solution.
Is there any reason, whatsoever that a box section sill like some people have used on their Nivas couldn't be used here? Box section, even thick enough stuff to do this with (bearing in mind that the original sill wasn't exactly thick) is comparatively cheap. The worst affected part here *was* basically just a box with an open top. Once completed it would be more sturdy than the original if anything.
Plus I can get all the bits I need for that locally and within a couple of days.
Sure, I'd lose the jacking point - but that could be easily reattached, and I reckon it would be solid enough a structure that it wouldn't really be needed.
Hoodoo
No rank
Post by Hoodoo » Tue Nov 01, 2011 7:53 pm
No reason at all, although the purists would object!! But, it's your motor, so, if you're happy that it fits and can be welded, go for it! It'll be stronger and, as you say, jacking points can be installed after.
Regards,
Hoodoo
'03 Niva 1.7si
Post by Zelandeth » Tue Nov 01, 2011 9:33 pm
Given the overall state of the van, it's never going to be a showpiece (well, save for the likes of my local shows where the approach is "if it's interesting, bring it!"). My approach here really is to get the thing solid, and to do it in a way that's going to give it as little chance to rust again in the future.
Plus I couldn't really care less what the purists think...there seems to be a huge amount of VW snobbery out there in a lot of places, and I think at least one being restored with a bit of realism and economy in mind isn't a bad thing. I'm not wanting to cut corners at the cost of the van, but if I can do it for half the cost without compromising the quality of the job or even potentially making it better than when it left the factor...heck, yes please.
I need to carry out remedial surgery above the offside suspension mounting as the area above where the mounting hardware attaches has holes in it and I have serious fears that at some point I'm going to go for reverse, take the clutch out and have the suspension arm go through the floor!
If we were to do something like this, my approach would be drill a hole in the bracket (which I think it actually has in anyway if memory serves right, large load spreading washer on both sides, line up, secure then weld that on as well. That way Mr. MOT Tester shouldn't have any doubts about its ability to remain where it should be. Think the photo below shows the problem area pretty well
There have actually been more holes poked in the sill around there since this photo was taken. I know the bottom inch or so of that chassis outrigger are shot too - that's not complicated to sort at least (and appears to be the only dodgy bit of chassis surprisingly enough).
Think this is without doubt the most "difficult" bit of rust to sort out that I've found so far. The sink drain by the way will be re-routed through the vent in the floor you can see in the upper right of that photo, rather than through a hole in the sill as it previously ran.
GadgetBoy
Post by GadgetBoy » Tue Nov 01, 2011 9:35 pm
Don't the pipes/vents for the heater run up the sills?
Post by Zelandeth » Tue Nov 01, 2011 9:48 pm
Nope.
From the heat exchangers...
Into this, then to the cab air distribution control unit.
Think the Beetle might have used the sills though.
GadgetBoy
Post by GadgetBoy » Tue Nov 01, 2011 9:52 pm
Yes the Beetle does use the sills. That's why I asked.
