AAAAAAAAAAAAAAAAAAARGHHH!!
Post by GadgetBoy » Thu Oct 20, 2011 6:28 pm
At what RPM? Honda compensate for bad design by throwing revs at the engines. With a properly designed inlet tract the very same engine would easily exceed 200bhp with significantly more torque and tractability.
mooshaker
Silver
Silver
Post by mooshaker » Thu Oct 20, 2011 7:12 pm
i worked for Honda for 10 years building cars and left due to where they are going with what they build now and in the future the old red top is doomed in europe ...:o( also the build quality is going to shot ...my old fiat lumps would rev just as free as a honda sit all day at 8000rpm and bounce off 10000rpm :o)
speedy
Post by speedy » Thu Oct 20, 2011 7:29 pm
Let's hope it's fixed for buildwas as I'll need some one to pull me out when I get stuck lol or break something haha
Www.dirty-torque.net
Lada Niva ex works gone ;(
Jimny next :-p
speedy
Post by speedy » Thu Oct 20, 2011 7:49 pm
Best get fixing mine then let's hope the axles doesn't fall off again lol haha Might steal one of dads battery's lol no more flat battery for Dean haha
Jimny next :-p
integraR
Post by integraR » Thu Oct 20, 2011 11:24 pm
well that went off topic a bit :lol: for me the b18 is the best all round engine I have ever had the pleasure to drive, I know the d series used pgmfi which was a complex ecu system, was this to make up for the poor inlets??
tempted to turbo the twin cam then? nudge nudge, just so I see what it goes like :lol:
Hand painted black niva 96 1.7I aka the problem child!
96 spec Integra type R aka the rice rocket!
integraR
Post by integraR » Fri Oct 21, 2011 9:09 am
think i just had a crisis :lol:
supercharger sounds just as much fun, we are bad really egging you on with a car that your trying to keep simples! The 205 should be fun once the engines in.
Post by excossack » Fri Oct 21, 2011 11:58 am
A vtec powered pug 205?
mooshaker
Silver
Silver
Post by mooshaker » Fri Oct 21, 2011 4:19 pm
if i remember rightly just prior to the old type R being built it was ran bare shell and it revved out doing just over 170 mph ...white knuckle in a Niva :o)
baxter
Post by baxter » Mon Oct 24, 2011 1:59 pm
GadgetBoy wrote:The design and implementation of the inlet tracts is truly woeful in terms of airflow management and rough as .... in actual manufacture. If Honda had done the inlet system correctly they would be great engines. You should read what Guy Croft thinks of them.
So Honda engines are "complete shite" because their inlet manifolds are not 100%.
I'm guessing you're never been in quick vtec then. :lol:
Even with the apparently crappy inlet manifold they blow away any other equivalent NA car I've driven. And as Simon says they're completely tractable while doing it.
And I wouldn't be too sure about the alleged flaw in the manifold design; I don't know a lot about vtecs but iirc many of the after-market inlet manifolds actually loose power and the factory one is ok for anything up to serious internal mods.
Honda were experts in flow: The ZC engine (pre-vtec) in my CRX has such great flow from the factory that many engine tuners get less power by dicking around with the ports. It's generally accepted the the flow only needs work on very highly modified ones.
And I've thrashed the crap out of several Honda ZC motors (ie in motorsport) and am yet to kill one.
Post by Neil Chowney » Mon Oct 24, 2011 8:42 pm
Simon, mine was on the speedo so its probably a bit shy but they do pull like a train in good stock trim.
Mine is totally standard, and in good nick, burns NO oil and has standard carburation.
Post by Zelandeth » Mon Oct 24, 2011 9:38 pm
If you've got hesitation something's not 100%. If the carb's not 100%, the engine's never going to give its best. I had similar problems with a Saab, in hind sight I should have just rebuilt the darn carb rather than keeping swapping out for different, but equally knackered ones!
What you're saying there regarding stuttering after long periods of high revs, sounds almost like you might be suffering fuel starvation?
I'd either give the carb you've got a service, and give everything else a good service while you're at it before making any judgements.
Imagine the carb would need to be re-tuned for the new engine as well, especially if it's been set up to compensate for the wear on the old one.
Post by excossack » Wed Oct 26, 2011 10:19 am
Megasquirt conversion ?
baxter
Post by baxter » Wed Oct 26, 2011 12:05 pm
SimonAllen wrote: Will a rebuild kit solve the butterfly having play in the shaft?
Weber?
No sadly, it'll need to be machined and bushed or oversize shafts iirc; and it's a specialist job (someone here did a neat looking job with a drill and the result was no where near accurate enough).
There's some neat looking little bearing inserts that used to be available.
Worn shafts can give endless problems, and are why I'm back on a VAZ carb as all my old Webers have the problem to some extent.
mooshaker
Silver
Silver
Post by mooshaker » Wed Oct 26, 2011 4:49 pm
i was always told to avoid HIF`s and use any of the older types with float chamber on the side..which i did on my fiats ...only problem i had was freezing up at about 7500 rpm ish , i bought some fuel additive and that cured it along with a x19 carb fan with thermostat as when it got hot it vapourised .....you can buy a kit for a su to fit on a ford cross flow so would imagine you could cobble that to fit a lada
Post by Neil Chowney » Wed Oct 26, 2011 6:47 pm
Simon, what carb is on yours? It should be an ADF 34 which is pretty good.
