bonet cut for snorkle
iain couttie
Post by iain couttie » Fri Jan 06, 2012 6:24 pm
i managed to get a snorkle for my niva, when it arrived i was expecting to have a template for cutting the bonet,there was not.I am looking for advice on the best way to go about it without making a mess of it.If it makes any diference it is made by a company called goliath and was bought from istambul.
iain
Re: bonet cut for snorkle
Post by GadgetBoy » Fri Jan 06, 2012 9:32 pm
The normal way would be to drill holes at the corners of the required cut-out and either use a jigsaw or snips to do the straight lines. If you're being really picky you cut about a centimetre shy of what you actually need and then fold the centimetre back to give you a nice edge.
You should be able to make youself a decent enough template from card and the end of the snorkel.
iain couttie
Post by iain couttie » Sat Jan 07, 2012 6:44 pm
thanks, managed to get a tidy job with a 9 inch angle grinder. was a lot easier than i thought.as usual thanks for the response to my endles questions.
iain
