Can't fault the logic there then, Gadget!
Do you think the proposed repair method for the suspension arm sounds plausible? There are two front mounting points for the trailing arms, so it shouldn't be too hard with some careful measuring and lots of marks scribbled around the general area to get things lined up properly. Using the bolt as the first means of securing helps too as it gives the opportunity for fine-tuning prior to the final, final securing of everything.
1980 Volkswagen T25 Camper Van Restoration Project
Excellent.
Okay, next question (suffice to say it's the first time I've done something like this, so there may be a few of them...).
What size and thickness of box should I be using? In Vlad's box-section sill replacement thread 3mm thick section was used. At least to my head that sounds sensible, if not slightly overkill. I'd rather go for overkill than the opposite.
As far as the actual size is concerned, I imagine just going for what fits the gap left by the absent sill would be the best approach - which is about an inch and a half in width I think where it should meet the outer sill.
Thinking given the similarity in size, that I could probably resolve the issues with the crusty bottom few inches of the chassis outrigger with a similar bit of box too.
Basically this will involve "improved" body structures being applied as shown below. The red triangular bit is just a conventional plate which will be needed to close off an area where there would be a void. Will likely reinforce this too.
May well end up doing something similar on the passenger side yet if this works out well!
Re: 1980 Volkswagen T25 Camper Van Restoration Project
i worked on overheads at honda for 10 years and you would not believe how far out some floorpans /sus mount points were so im sure you can do a top job on that ) .....100`s of civics have my chewing gum in a hole in the floor to stop water getting in
Let's try that again with less IT problems this time...
Think this should be doable - even with my limited experience! Plus side is that I've found that the jacking point/trailing arm mounting points are available new so A: I don't need to worry about getting the old one off in a usable state, and B: It means that other people have done it!
Found another couple of posts elsewhere, and it does sound like a case of cut off, repair area under it, line up and weld on new bracket, re-attach trailing arm.
