Welder (again)
Welder (again)
Hi, I'm looking at welders again and wondered if I could run a couple past you guys (sorry) not got a massive budget as I'm a student (Automotive Electronic Engineering at Sheffield Hallam Uni).
Basically I'm needing it for basic body welding no massively structural, (current jobs: wing tops, heater box mounts, drivers foot well, patch in sill (actually this is the first time I've wrote it all down and it sounds like a lot!!)).
I've not done any welding before so I'm going to have a go at teaching myself before I turn to the car. I know a few welders so not too much of a problem.
Anyway this is the first one.
http://cgi.ebay.co.uk/SEALEY-100Amp-No- ... 2752wt_905
1990 Riva 1300
Thanks GB,
this one is Gas/Gassless and its close to me so I should be able to pick it up. Only problem is, it says that it can only run on low power settings from a 13amp socket. Will the "low power settings" be enough for my needs?
Thanks again,
Daniel.b
http://cgi.ebay.co.uk/Wolf-Mig-140-Gas- ... 5676739835
Thanks again,
Daniel.b
1990 Riva 1300
It says down at the bottomGadgetBoy wrote:That's perfect.
Where does it say you can only use low current settings on a 13amp plug? That's bollocks anyway.
"Q: will this plug straight into a NORMAL house socket? ie, 13amp house plug? cheers ash
A: This will operate at its lower power levels from a 13 amp house plug (not supplied), however to use at its full power settings we recommend using a 30amp plug and socket supply. Regards, "
Thanks guys I think I'm going for that one, (finally).
Daniel.b
1990 Riva 1300
Well that's a relief . I looked at a few "how to" guides for the range and it doesn't seem to mention it either.
Has any body on here ever had any experience with "Wolf" welders, a few people on the http://www.mig-welding.co.uk complaining about them. They seem to be under the impression that they are Live torch machines but it clearly says in the Advert "Non live Torch". There are also very positive comments so I'm a bit confused.
Sorry for all the questions but I don't want to spend the extra for a Clarke but at the same time I don't want to buy twice.
Thanks again,
Daniel.b
Thanks again,
Daniel.b
1990 Riva 1300
I've occasionally tripped a circuit breaker with my mig on full power and blown a fuse in the plug too. A clarke 140 Turbo Weld if I recall.
But then our set up is far from ideal. The shed is powered off a single long extension lead that runs the lights, radio, etc. And the lights flicker when it's running.
Just about to bid and thought I'd get some experianced views.
http://cgi.ebay.co.uk/Clarke-PRO-110E-M ... 35b02dadfb
thanks again,
daniel.b
thanks again,
daniel.b
1990 Riva 1300
re welder
yeah that one is ok ,couple things, gas cylinder gonna be to small best find a landlord an get a co2 bottle from him most weld shops exchange them also at that amperage use 6mm wire in an 8mm tip less blockages and easier to get a burn going,if that model takes the larger rolls of wire its a bonus the small rolls dont seem to last that long, then its good earth and plenty practice so should be ok with a niva regards jick
ps, never tie ur boot laces up when your welding
1992 niva 1.6,dodge w200,trident tycoon,dodge50series
