| Author |
Message |
vlad Bronze
Joined: 11 Jul 2009 Posts: 178 Location: Cambridgeshire
Posted: Fri Aug 21, 2009 9:58 pm Post subject: sill replacement with box section (in pictures) |
I bought my Niva about a month ago and having been used on a farm for 3 years there was no MOT. First glance underneath revealed the need to repair/replace the sills, so i decided to replace with 3x3 box.
The reason:-
Cut old inner sill out:-
Prepare box section by 'capping' ends
And trial fit before welding in:-
first need to sort outer sill:-
Weld it in and treat to a little paint:-
(notice i had to make a new 'outrigger' for the fronts also (60x40mm box)
A little seam sealer for good measure:-
And a lick of underseal to finish off:-
I got rid of the original jack points but figured 3x3 box should stand up to a little jacking, if not i will add some 3/4 box underneath so i can use the original jack as intended. _________________ Lada Niva 1.7i aka 'Vlad'
Skoda Octavia VRS aka 'Skud missile'
Husqvarna SM610 aka 'Husky'
VW Corrado project car aka 'Project Tango II' |
| Back to top |
De-Ranged Bronze
Posted: Fri Aug 21, 2009 10:15 pm Post subject: |
Nice I wish I could do this to the trails truck, rules don't allow it
just a thought if your worried about collapsing the box, wouldn't it be easyer to make a wider contact foot for the head of the jack?
The strength will depend on the wall thickness of the box section 3mm+ I wouldn't worry about it
Cheers Reece |
| Back to top |
vlad Bronze
Posted: Fri Aug 21, 2009 10:19 pm Post subject: |
wall of box is 3mm so should be ok as you say. My existing jack (in one of the pics) was at it's max and just about held the box in place to weld it. A load spreader will thus kill two birds wit one stone so i can actually get the thing in the air  _________________ Lada Niva 1.7i aka 'Vlad'
| Back to top |
ahma Gold
Posted: Fri Aug 21, 2009 10:25 pm Post subject: |
I lift mine with the Hi-Lift straight up and my sills are just 60*40*2!
 _________________ /mats
Niva -94 1.7 TBI *daily driver *
Niva -96 1.7 TBI *future unknown*
www.lada-niva.se |
| Back to top |
crb247 Diamond
Joined: 03 Feb 2008 Posts: 2384 Location: Sault Ste. Marie, Ontario, Canada
| Back to top |
eosullivan Bronze
Joined: 25 Mar 2008 Posts: 225 Location: bantry co cork EIRE
Posted: Sat Aug 22, 2009 9:47 am Post subject: |
Hi Vlad.Is thereany chance you could post a picture from the outside looking in!!.You did an excellent job on those fitting those box sections.Eugene _________________ Owner of 5 LADA NIVA's and 1979 Opel kadett Coupe |
| Back to top |
vlad Bronze
Posted: Sat Aug 22, 2009 10:57 am Post subject: |
B****r me, i knew i'd forget something
will get a pic tonight but basically they come down as far as the original sill lip so there is no loss of ground clearance. _________________ Lada Niva 1.7i aka 'Vlad'
| Back to top |
SimonAllen Diamond
Joined: 11 Jul 2006 Posts: 2298 Location: Telford, Shropshire
Posted: Sat Aug 22, 2009 12:34 pm Post subject: |
a very tidy effort there mate
mine will go this way at some point if i keep it, as I tend to drive over things i perhaps shouldn't  _________________ 1996 2.9v6 lada niva auto
"Don't be scared of trying. The ark was built by amateurs, yet the titanic was built by professionals" |
| Back to top |
Hoodoo Titanium
Posted: Sat Aug 22, 2009 7:44 pm Post subject: |
| SimonAllen wrote: |
mine will go this way at some point if i keep it, as I tend to drive over things i perhaps shouldn't  |
Mine attacks the occasional boulder as well!
Regards, _________________ Hoodoo
Buckley, North Wales. |
| Back to top |
SimonAllen Diamond
Posted: Sun Aug 23, 2009 9:40 am Post subject: |
thought you were trying to keep it quiet! _________________ 1996 2.9v6 lada niva auto
| Back to top |
Hoodoo Titanium
Posted: Sun Aug 23, 2009 7:29 pm Post subject: |
Not possible. Your Mum knows about it!!
Regards, (running for cover - again!) _________________ Hoodoo
| Back to top |
vlad Bronze
Posted: Sun Aug 23, 2009 9:21 pm Post subject: |
Pics from outside as requested
| Back to top |
Ned Bronze
Posted: Mon Aug 24, 2009 1:24 am Post subject: |
| Vlad is that your niva in your av? |
| Back to top |
vlad Bronze
Posted: Mon Aug 24, 2009 7:27 am Post subject: |
| Ned wrote: |
Ha Haa I wondered if that would get noticed, it is mine (which is currently white) but with a little help from a friend (ok, he did it) it was photoshop'd. That is roughly how i want it to end up tho'  _________________ Lada Niva 1.7i aka 'Vlad'
| Back to top |
Ned Bronze
Posted: Mon Aug 24, 2009 11:50 am Post subject: |
| i like it |
| Back to top |
