FREE Online Virus Scanner
Lada Parts UK Forum Index Lada Parts UK
Welcome to the Lada forum
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Free online virus scanOnline Virus Scan   Log inLog in
Search the knowledgebase
DIY Rockcrawler Kit - production STARTING AGAIN! -
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Post new topic   Reply to topic    Lada Parts UK Forum Index -> General
  View previous topic :: View next topic
Author Message
Aman
PostPosted: Fri May 07, 2010 11:25 pm    Post subject: Reply with quote
Lada & Korean Parts wrote:
different ratios in t/cases between 4.3/4.1 & 3.9
you will see in parts cats they have different countershafts.
Ehm... NO!!
Ehm....parts cats & workshop must be wrong then...... Rolling Eyes
Apparently yes!! Razz
_________________
'97 Niva 1.9TID 31" tiers, steel front diff, "The French Mod" T-Case, 4.3 diffs, ZF Servo.
'94/'96 Niva 1.9D stock -For Sale-
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
NIVAD
Silver
Silver
PostPosted: Mon May 10, 2010 4:56 pm    Post subject: Reply with quote
Many thanks too you all
Ive done mine now after watching the videos and asking questions-thanks again.
Cant wait too give it a go in the mud.
Just thought id add some of my finds.
As youve said your oil was contaminated- so i decided to before putting props on to put some miles through TC case.
First batch of new oil came out almost grey/silver with lots of bits of metal present(very small)
Also metal on magnetS----i added another magnetic plug to the filler hole Very Happy
I progressed to changing the oil 4 times just too try and take as much out as possible.
When positioning the big gear on the shaft i tried too weld it on with as i was told proper rods for hard steel--these didnt work and cracked straight away (next time i would warm them up a bit??)
Will hope that the interferance fit which i believe is all youve used will be enough?
Well if one will brake it will be mine with my welded rear diff and chunky tyres--Lets hope not though.
Thanks again and ill let you know how i get on
First thoughts are nice contolable power- going over big tyre in 1st Very Happy
_________________
Paul
Birmingham
Niva Pickup diesel,niva 1600,Disco, mini,Rover with pug engine,Vw Sharan.
Back to top
niva nut
PostPosted: Tue May 11, 2010 10:35 pm    Post subject: Reply with quote
Good luck with the off road testing Very Happy I am sure it will be ok, you won the race mate Wink
_________________
Allan
Back to top
ahma
PostPosted: Fri May 14, 2010 1:12 pm    Post subject: Reply with quote
Production of modified shafts is halted. Micke can't get new shafts from Russia for the moment.
We could need a realiable supplier that know how to get a good price from Lada and also can help with shipping and toll and all other paperwork at the borders...
The bits are heavy - and transportation easliy cost more than the parts - unless we can find another way to get them to Mickes workshop in Sweden
Ideas?
_________________
/mats
Niva -94 1.7 TBI *daily driver *
Niva -96 1.7 TBI *future unknown*
www.lada-niva.se
Back to top
TheRealNivaman
PostPosted: Fri May 14, 2010 1:19 pm    Post subject: Reply with quote
What parts do i need to supply if i was to fit this into my t/case?.
Third gear and ???.
Back to top
ahma
PostPosted: Fri May 14, 2010 1:22 pm    Post subject: Reply with quote
Welding on the modified countershaft is a big no-no. You will only add internal tensions in the material and maybe even a "indication of fracture" (?) The shrink-fit is more than enough.
Even if the shrink-fit would slide a few degrees, it will "sieze up" (?) at once and be jammed forever!
Sorry about guessing words and using dictionary - hope the message comes though!
_________________
/mats
www.lada-niva.se
Back to top
ahma
PostPosted: Fri May 14, 2010 1:25 pm    Post subject: Reply with quote
Third gear and ???.
We need one countershaft, and one crownwheel from a 1600 TC. That will become a Rockcrawler countershaft. THEN you will need an additional third gear wheel when you put it together, at home
_________________
/mats
www.lada-niva.se
Back to top
TheRealNivaman
PostPosted: Fri May 14, 2010 1:29 pm    Post subject: Reply with quote
Crownwheel from center diff yes?.
Back to top
ahma
PostPosted: Sat May 15, 2010 9:23 am    Post subject: Reply with quote
There is just one crown wheel in TC... Wink so: yes - from center diff!
_________________
/mats
www.lada-niva.se
Back to top
NIVAD
Silver
Silver
PostPosted: Mon May 24, 2010 8:18 pm    Post subject: Reply with quote
WICKED mod very much recommended.
I enjoyed being able too control a low speed and taking my foot off the brake on a steep incline was easy with the aid of lifting the clutch much easier.
I got a good test 2 days of some very dry and hard surfaces,
I broke a half shaft which caused me too remove my welded rear diff which i wont be putting back in as i prefer it now.
I would strongly recommend this so get your shafts off the man.
Cheers Very Happy
_________________
Paul
Birmingham
Back to top
TheRealNivaman
PostPosted: Mon May 24, 2010 8:39 pm    Post subject: Reply with quote
Cheers Very Happy
What you prefer no diff??, Wink
Back to top
milhouse87
PostPosted: Tue May 25, 2010 8:17 pm    Post subject: Reply with quote
dam dam and dam, I was lining up to buy one of these in a couple of months, now I will have to pull my spare TC apart when I get home and send off the parts, but by the time I get them back it will be too late. Sad
please please let us know if you find another way to get the parts, you are doing the whole lada world a favour and for that you should get a medal.
_________________
GO the ALL BLACKS
Back to top
View user's profile Send private message MSN MessengerSkype Name
SimonAllen
PostPosted: Wed May 26, 2010 8:20 am    Post subject: Reply with quote
Dad is going to be building one shortly. If I was ever to go back to a manual niva this would be one of the first things I would do. paul's seemed awesome
_________________
1996 2.9v6 lada niva auto
Car mechanical/electrical work undertaken in telford. Doesn't have to be a lada! PM me for details.
Back to top
ahma
PostPosted: Thu Jul 29, 2010 8:24 pm    Post subject: Reply with quote
Good news from Micke! Parts are arriving from Hungary, and in a few weeks he plan to do some new shafts.
Prices will be adjusted and announced here.
You who have written to me and have got none or negative response - please remind me with a new PM!
...and remember we do not do this to make money... have some patience...
_________________
/mats
www.lada-niva.se
Back to top
ahma
PostPosted: Mon Aug 02, 2010 8:07 pm    Post subject: Reply with quote
Well, a man's got to do what a man's got to do...
3:1 Rockcrawler AND 4,3:1 in the axles...
Link
_________________
/mats
www.lada-niva.se
Back to top
Display posts from previous:
Post new topic   Reply to topic    Lada Parts UK Forum Index -> General All times are GMT + 1 Hour
Page 7 of 8
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot moderate your topics in this forum
Powered by phpBB © 2001, 2005 phpBB Group
