let's not go there shall we.........excossack wrote:As long as its a crotchless thong you will be fine
Got really odd looks carrying a middle exhaust section for a Riva through the middle of Aberdeen this afternoon!
Still, at least nobody tried to arrest me for carrying an offensive weapon or something stupid like that.
Well you certainly won't be listening to any lies about low ink levels from that printer any more!
Ahhhhhh. Problem is, it still says empty everytime its used its 7.2ml. So you just take them out for 2 mins and it resets the chips. =)Zelandeth wrote:Well you certainly won't be listening to any lies about low ink levels from that printer any more!
Much cheaper than paying epson prices!
1990 Riva 1300
Just ordered a similar thing for my HP Photosmart Premium. It's about to need four new cartridges - so I was only going to be about £10 short of the cost of the kit! Bit of a no brainer really!
No need to dismantle things here when it thinks it's empty, as you just hit OK to continue when it flags the warning up. Think there's actually an option in the menus to disable that too if I remember right.
No need to mess around with fooling lid sensors or anything either, as there's a little blue bit of trim that I can remove which will make a perfect channel for the pipework to exit through. Bonus!
Thanks for reminding me I was going to look into that! Had clear forgotten!
A bit of a shock there John..Hoodoo wrote:Stopped being a Difflock member!
Really cannot stand the self-important attitude of the Moderators on there!
I can see why you've done what you've done. Will miss your posts.
Just dont leave here !
Attended the Cambrian G-O-N Rally based around Penmachno forrest, and a few other places
Recovered a stuck, beached, broken down Scooby. It needed winching off a tree stump it had landed on, damaged the rad, removed some belts and left it high and dry.
A quick tug with the winch, some shoving and grass clumps removed it popped off the stump.
It did need a straight tow to the end of the stage which was about 5 miles through the forest.
1. In an attempt to figure out what on earth the boost system in the Cappuccino is doing (periodically dumping boost violently under hard acceleration and trying to throw me through the windscreen), fitted a boost gauge. Discovered that it's boosting to about 1.1 bar (should be 0.6-0.7). So what's happening is the ECU's tripping in the boost cut system (which kicks in at 1.13 bar) to help prevent the engine blowing up. Hmm. Will take the air filter, battery and three million hoses off next week to investigate the plumbing around the wastegate actuator etc. That'll be fun.
2. Discovered that local garage has screwed up and got me the wrong middle section for my Riva's exhaust. Will get it sent back, refunded then buy one from Neil. Moral of the story, trying to save £10 really isn't worth it sometimes!
3. Bodged existing Riva exhaust so that I can at least run the car without everyone thinking a light aircraft has started up outside. Bodge involved 3 U-clamps, a tube of firegum and an empty spray can. ...For the first time since I've had the car, the exhaust isn't blowing! Still, it'll need replaced for the MOT.
