Joined Twitter....
@vaz21214 for a change
Followed
Downloaded a bunch of 3D software for free from Daz 3D who have a might attractive looking promotion on just now. About £600 worth of software available for free.
Still playing around with Sculptris which I got hold of a while ago as well...in addition to the good old pencil of course. Too many things to play around with, too little creativity and too little time!
Planned a 4pm dart from work to get the starter motor back in the Landy.
14:30 Server goes pop - blown PSU, discover no hardware support for the server.
Scrabble round, find another server of the same model but different generation. Same PSU fitting but wrong side of the system board...Server backup and running by having it hanging out the rack supported by a server lifting machine and the PSU placed in the space of the old one...
16:00..VM Ware cluster goes TU.... and servers start failing over....Not helped by the SAN guys extending disc partitions, causing excessive load on the SAN.....
17:20 finally ready to go home.
Get home 17:40, and proceed to get starter motor fitted while holding the torch in my mouth.
Two out of the 3 bolts back in and the wiring done. Finish off the fiddly bolt tomorrow.
I think that must be the latest patch from HP. Voice and thought recognition.!
Here is the Server / Rack
- server rack-web.JPG (82.14 KiB) Viewed 18188 times
Managed to leave work at 16:20 to get on with the Landy. Starter motor bolts back in, wires back on and battery reconnected....and brum she starts! Early impressions, she starts quicker...Will see what its like tomorrow morning.
Im 21 years old and I feel like 60 years old.
Today I mostly thought about myself. And found out nothing smart. The more you think, the worse it is, if you ask me..
My main problem is that i've become isolated. I don't go out anymore. I am mostly alone and go to places, where I am even more alone. And the worst thing is, i actually feel ok. But then when at one moment it hits you.. And i've come to conclusion.. Happiness is only real when shared...
'95 Niva 1.6 Horror Carbed
Picked a niva transfer box up from huddersfield..
Cheers Gav
Cheers Gav
Purchased a hot glue gun to fix my working in the garden/on the car boots.
This evening I mostly...Performed a bit of a chronological cut-and-shut.
I've had a Sony TFM-C580E clock radio which had been shunted into retirement due to a noisy reduction gearbox making it too noisy for bedroom use and a couple of damaged digits.
A few days ago I managed to pick up a rougher looking example off eBay, which does at least appear to be running silently so far. This evening the clean case from my previous one was transplanted onto the chassis of the eBay example.
Result is shown below.
This isn't where it will live - it's just a corner I could stick it out of the way while it's on soak test...
1975 I believe.
Today I mostly got given
4 x 6" angle eye spot lights
4 x 7" Hella spot lights
Finished work for a week off
Car played up again last night. 2hrs trying to get the ****** going, In the end I did by putting a jump lead from the battery to the solenoid wire connector.
So the weekend is working on the car to get workout whats going on and try and get it fixed.
Its certainly a Land Rover ! The badge says so....
