FREE Online Virus Scanner
Lada Parts UK Forum Index Lada Parts UK
Welcome to the Lada forum
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Free online virus scanOnline Virus Scan   Log inLog in
Search the knowledgebase
New way to adjust T-box - "Voodoo" - opinions?
Post new topic   Reply to topic    Lada Parts UK Forum Index -> Technical Support
  View previous topic :: View next topic
Author Message
ahma
Gold
Gold
PostPosted: Sun Aug 10, 2008 5:54 pm    Post subject: New way to adjust T-box - "Voodoo" - opinions? Reply with quote
After some serious offroad in weekend it felt like nothing under the car was quite in the right position. T-box had slided, mountings bent and floor was dented.
Laying under the car, looking at the U-joint I could see it working and the dougnut flexing. Just moving the case in the longholes did not seem to help. So, probably I also had a problem in the third dimension.
Using a 1,5 mm soft steel wire attached to the two halves of the UJ I made two needles pointing at eachother, 1 mm between them. Rotating the UJ I could then see what happened, distance between points changing. After adjusting the T-box 4 mm up, and lower G-box 2 mm I could then usethe longholes to adjust sideways. The needles works best when positioned like in the second clip, in line with the UJ-cross. Some white paint on the points helps to see them in the darkness.
EDIT: Of course the distance between the point should be the same during a full turn. A difference upper-lower may be corrected by moving in longholes parallell - and if thats not enough by using schimms for T-box or G-box. After doing height adjustments, compare the distance right-left and use longholes to adjust. Repeat until satisfied.
Link
Before
Link
After
What do you think?
_________________
/mats
Niva -94 1.7 TBI *daily driver *
Niva -96 1.7 TBI *future unknown*
www.lada-niva.se
Back to top
View user's profile Send private message Visit poster's website
Hoodoo
PostPosted: Sun Aug 10, 2008 6:18 pm    Post subject: Reply with quote
That's worked very well and gives an accurate indication of what's going on. Good job.
Incidentally, accurate alignment of gearbox output and transfer box input is essential regardless of whether there's a UJ or CV fitted to the intermediate shaft. Although the CV joint will accommodate more deviation in alignment than the UJ, it still needs to be properly aligned. Be prepared to space the transfer box and, if necessary, the gearbox to achieve this. It's the ONLY way to get proper running.
Regards,
_________________
Hoodoo
'03 Niva 1.7si
Buckley, North Wales.
Back to top
ahma
Gold
Gold
PostPosted: Sun Aug 10, 2008 6:21 pm    Post subject: Reply with quote
Is this the "Voodoo adjustment method"? With needles... Very Happy
_________________
/mats
www.lada-niva.se
Back to top
Hoodoo
PostPosted: Sun Aug 10, 2008 6:27 pm    Post subject: Reply with quote
As long as they're not stuck in me, I'll be happy! Very Happy
It's a method I'll use in the future, though.
Regards,
_________________
Hoodoo
'03 Niva 1.7si
Back to top
SimonAllen
PostPosted: Sun Aug 10, 2008 6:44 pm    Post subject: Reply with quote
looks very simple yet somehow genious!!
well done, I'll be checking mine this way!!
_________________
1996 2.9v6 lada niva auto
Car mechanical/electrical work undertaken in telford. Doesn't have to be a lada! PM me for details.
Back to top
Alejoint
Gold
Gold
PostPosted: Mon Aug 11, 2008 2:11 am    Post subject: Reply with quote
That's plainly brilliant, Mats. Thank you very much for sharing it with the rest of us.
*Runs to spread the good news to other Niva forums* Laughing
_________________
Alejandro Gabatel
1991 Niva 1600
1992 Ford Bronco 4x4
FRONT DIFF BRACKET PROJECT
Back to top
baxter
PostPosted: Mon Aug 11, 2008 9:45 am    Post subject: Reply with quote
Excellent idea.
I'll likely also copy this next 'box swap...
PS - anyone know how to copy Youtube to disk (the app I used to use doesn't work any more Sad ).
_________________
1990 Niva 1600, Weber & 2" lift
Baxter's Temple of Niva Site
Back to top
ahma
Gold
Gold
PostPosted: Mon Aug 11, 2008 10:11 am    Post subject: Reply with quote
Thanks! Smile I'm happy if I can make a small contribution, a way to "payback" for all good info I have recieved from this forum.
If someone would like to try this and then make a proper "How-to" in English (..not in my version of Swenglish...), and post it here I would be even more happy! I have some problems finding the best words to describe the procedure.
_________________
/mats
www.lada-niva.se
Back to top
NIVAD
Silver
Silver
PostPosted: Mon Aug 11, 2008 7:45 pm    Post subject: Reply with quote
Laughing Laughing Laughing Laughing
EXCELLENT
_________________
Paul
Birmingham
Niva Pickup diesel,niva 1600,Disco, mini,Rover with pug engine,Vw Sharan.
Back to top
bodgit0_0
PostPosted: Mon Aug 11, 2008 8:13 pm    Post subject: Reply with quote
I will be using this method for the final alignment o the diesel project....
Well done that man..
Lee
_________________
1952 S1 Land Rover V8.
1956 S1 Land Rover Daily Classic
1988 Montego Estate MG A challenge!! F700 SUY
1993 Maestro TD Tweeked
1995 Land Rover Disco 300tdi tweeked.
1997 Lada Niva going Perkins Prima.
Back to top
NIVAD
Silver
Silver
PostPosted: Wed Aug 13, 2008 7:36 pm    Post subject: Reply with quote
Mine vibrates at 60mph but if i give it some 80mph it goes trouble is Nivas dont feel too good at that speed Very Happy
_________________
Paul
Birmingham
Back to top
crb247
PostPosted: Wed Aug 13, 2008 11:48 pm    Post subject: Reply with quote
I vote to make this method a sticky Very Happy !!!
_________________
'96 Niva 1.7i Cossack - Daily Driver
'98 MPV 4X4
webby-http://sites.google.com/site/ladacanada/
Back to top
View user's profile Send private message Send e-mail
Display posts from previous:
Post new topic   Reply to topic    Lada Parts UK Forum Index -> Technical Support All times are GMT + 1 Hour
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot moderate your topics in this forum
Powered by phpBB © 2001, 2005 phpBB Group
