Video Editing...
Video Editing...
Anyone do it/tried it?
Currently im working on a 4.2gb mpg2 file rendered by Vegas 4.0 from a selection of AVI files.
Im not sure what went on but when i rendered the avi files to an mpg ive ended up with 1.49mins of video footage at the start that was actually recorded at the end of the tape. What i need to do is remove the first 1.49mins totally or remove it from the beginning and drop it at the end.
I can remove it OK but i end up with 1.49mins of blank footage at the start and then its in the correct sequence.
Anyone suggest a easy to use bit of software to trim the offending bit of footage?
Yeah, video editing takes ages and you need a powerful computer for anything in depth. I have done some ok stuff with Windows built in movie editor but your limited by your output formats. However, my brother has a thing for buying Serif software, and so I use a copy of Serif Movieplus which is actually alright.
It would be nice, maybe later on.
Maybe opensource is the answer.
A combo of Vegas and NeroVision did the trick. Managed a menu at the start of the DVD as well.
Ive got about another 6 tapes to do! thats me sorted for a week.
I edit professionally (and on Vegas no less -- the Niva of PC NLEs!).
You can re-import into Vegas, edit the ends, and then re-render. If you pick the EXACT setting you rendered the original file with, it will just copy what was already rendered but not edited -- so the rendering period will be minutes instead of hours.
However it sounds like there's a glitch in one of the files. I'd re-render the entire thing.
A 4.2gig mpg files is quite big. How many minutes is it?
I filmed a wedding back in July for a mate and wanted to put it on DVD for her. I tried it as MPG-2 file on a DVD and it wouldnt play so I used Nero Vison to make it into a DVD.#
Ive got some footage of some tractor pulling i may put on youtube.
Now i've sussed what im doing(although in a basic form) i can get on with the Honeymoon video from 2005 of Sydney and Cairns, some offroading and what ever else is on the tapes.
