Pretty quiet day today, which was a nice change as the last couple of weeks have been almost non stop.
Despite having a day off I tend to feel that it's necessary to achieve something in a day, even if it's something small. Having a new set of Invacar pulleys sitting in front of me it was obvious what this afternoon was going to involve.
While the secondary pulley was ready "out of the box" so to speak, the primary one needed a quick clean up first to deal with some aluminium oxide on the running surface.
Five minutes with the wire brush later it was much better.
For those playing along at home, here's a clear photo of the markings on the new primary pulley.
Getting the primary pulley off was precisely as much of a pain as I'd expected it to be. Simple reason: there is no easy way to lock the thing in place while you try to crack the retaining nut off. After snapping one large screwdriver and bending another, I finally managed to get it to cooperate.
Yes, that is a crowbar wedging the pulley in place. It later came into its own again while I battered it with a hammer to get the pulley off the shaft. The secondary one slid off pretty easily once unbolted, the primary was really quite a snug fit.
With it off it immediately became apparent that something wasn't right. The reason it rattled was because it appears to be completely devoid of any springs.
It never ceases to amaze me how knackered this sort of setup can be while still working to at least some degree...this felt absolutely fine anywhere below about 40mph!
The new secondary pulley looks to be a different type...but given the source I'm going to give it a shot.
Belt tension was checked after I'd rolled the car up and down the driveway a couple of times (yay...it no longer goes *click-squeak...click-squeak...click-squeak...* while moving at low speed. Seems reasonable.
Was only able to get out for a ten minute test drive this evening before dinner, but immediate impressions:
[] At low speeds the noise levels are hugely reduced. The actual noise you can mostly hear now is nice subdued tuneful transmission whine rather than howling belt.
[] Low speed responsiveness is slightly better. Though I think the tension is a little loose as it's a bit snatchy moving off.
[] Only did one higher speed run, but at 40mph plus things seem massively improved. I'm used to being able to just about hit 40mph between the one roundabout and our turnoff. Today an indicated 62mph (which I imagine is somewhat optimistic) was achieved with less than full throttle and leaving me plenty of time to brake.
Hopefully I'll have the chance to do a better test tomorrow. Initial impressions though are that it's improved things.
Oh, and while halfway round a roundabout the brake fluid warning light which I'd lost was spotted skittering across the floor. It has now been safely stuck in the box of random Invacar bits.
Reassembly was relatively painless, only slightly awkward discovery was that the keyway cutout in the new primary was shallower than on the old one, requiring a rectangular rather than square key. Luckily I've quite a few random shaft keys in the "drawer of random fasteners and similar stuff" and was able to find one that was a perfect fit in a couple of minutes.
Looking forward to a proper test drive tomorrow...after I've cleaned the windows! I did wipe them down briefly...but obviously not very well, and I totally forgot about the wing mirror.
Will 70mph be doable? Let's find out. Not worrying too much about breaking the belt in. Just isn't practical to drive gently for more than a couple of miles here...it's 20-30mph in housing estates or busy distributor roads where you need really to be able to get up to 50mph or so pretty rapidly if you don't want to be flattened.
Do have to wonder what anyone who saw me on the test run thought given the current cosmetic state of the car!
Initial experimentation with the soda blaster has yielded an absolutely godawful mess but little progress in terms of shifting the original paint on the Invacar.
Hard to tell if that's just my air supply not being up to spec or if it's just further evidence of the paint on there being able to withstand a tactical nuclear strike. The paperwork says the blaster wants air supplied at 50psi, and we had that shown solidly on the output from the regulator... I did experiment with setting it higher, which definitely increased the amount of mess generated, not sure if it actually improved the rate at which stuff was removed.
My entire garage is now about 1/2" deep in finely powdered sodium bicarbonate...oh well, at least it will smell fresh for the foreseeable future!
Guessing professional outfits would have a system in place to retrieve and reuse a lot of the media...
Today was our third visit with Star, the rescue dog we're looking to adopt. Today we actually took her out for a walk, helping convince the foster that we weren't going to do something absolutely daft the first time we left the house.
Everything went well, and it's been agreed that we will be adopting her. She will be coming home on Sunday morning.
A few photos from today - though they all seem to convey seriously huge levels of derp!
Wasn't deliberate...they just came out looking utterly silly!
Obviously nothing to show car wise as this took up pretty much the whole day. However I've a few things planned for tomorrow all being well. Given FotU is only a few days away I need to get my tail in gear to get TPA ready!
mostly - tried to fix a faulty abs sensor on the pug.
looks like the retaining pin for one of the handbreak shoes had come loose and somehow crunched the sensor.
of course the sensor itself is only held on by one little bolt, so really easy, straightforward fix...
... looks like you need to remove the spring, swinging arm, all break pipes, calliper, stub axle etc and you might then, just about be able to reach the bolt.
Ah, one of those jobs. They're always good for a laugh. There's probably a knack to getting it out without dismantling the whole car first.
Have made an executive decision regarding the paintwork on TPA. Simply that I've had enough faffing about. I'm getting things into a vaguely flat state then throwing paint on it. I could spend weeks (or months) trying to get a mirror smooth surface, but I think that's a task for another time. The most important thing I need to do with the car at this point in time is simple: Drive it!
Okay...step one. Remove all the residue from the soda blasting experiment. Just a bit left to deal with...
Gave the van a quick wash too while I had the hose out as it was getting difficult to see through the windscreen again. The joys of brick wall aerodynamics.
Have had another shot at clearing the fuel tank breather, I've tried several times so far but it's only in the last few weeks I've had access to compressed air, so could try zapping it with this.
Will remain to be seen if it's actually made any difference.
Back to the Invacar paintwork. Worst bit of the car was this wheel arch I think.
I just went after it with the sander to get it vaguely smoothed out, then set about chucking some primer at things.
Followed by some top coat. Still obviously needs a few more coats (and in fact covering the remainder of the car), but I think it will wind up looking better than it started out.
Really do need to get hold of a spray gun for the compressor though...this is costing an absolute fortune in rattle cans! Hopefully will get it to a state which would classify as "inoffensive from ten paces" in time for Saturday.
Had a brief moment of worry when I was just packing up when I spotted this under the van.
Despite the engine being a little oily, she never usually actually leaves anything behind so the leak definitely required investigation.
The oily residue I think is mainly leftover from the leaky cam box cover. She doesn't seem to use a drop between services (granted, there are nearly eight litres of oil in there!)...and this didn't look to be oil. First thought was brake or clutch fluid...however there was no visible source in the engine bay, and hydraulic fluid was still sitting happily on the max mark.
Eventually I tracked down the source - that vertical tube to the left of the alternator. Looks to be a drain from the heater intake box, so just a bit of water draining off from the earlier wash... nothing to worry about thankfully.
.... found where the water was leaking from in the house.
Over the past few days I have had a creeping stain up two walls in two seperate (but joined) rooms plus some weird random damp patches appearing on a concrete floor around the wet room.
Couldn't figure out where this was coming from and my worry was that it was one of the central heating pipes buried in the concrete floor.
The rising main for the house comes up right by the back wall in the wet room (was the downstairs cloakroom before I converted it). This comes out of the floor and then after a miserly inch and a half, turns through 90 degrees and runs parallel to the floor then up through a wall.
There was no wetness under or around the pipe so I had discounted this as a leak path.
Eventaully because I coun't think of anything else. I decided to hammer some of the concrete away around where the pipe disappears into the ground and lo an behold it was wet. I had to go down around three inches to find it but it is definietely coming from the underground pipe and then finding its way under the waterproof membrane under the wetrom floor and then being drawn up by the plaster walls a couple of feet away.
So my question is this.. what deranged, retarded, feeble minded, festering cockwomble of a plumber puts a copper pipe underground in concrete with no sleeving FFS!!!! Its corroded through due to the alkali in the concrete attacking the copper. This was put in when the hosue was built so it must have been done by the main contractors.
I now have to run a complete new palstic pipe to the main outside and connected it in UNDER MY BRAND NEW FORTY GRAND BLOCK PAVING PATIO!
When I find out who did this i'm going to dig him up, shoot him in the face and then bury him again in liquid manure.......
Grrrrr......
Grrrrr......
Ouch... probably the same idiot contractor who the previous owner here paid nearly ten grand to install our bathroom and had left live mains wiring sitting under the loft insulation, didn't put the heated floor temperature sensor actually in the floor, and had wedged plastic pipes into compression fittings. On the output from the shower pump too. This has been a running theme through the whole house.
I assume it's too far down the line for anything to be thrown back at the builders? Worth checking with the CAB, imagine yours won't be the only house there to have had the issue, so the makers may have been forced into sorting it at other properties. Just a thought really.
Knowing that the rattle can route was going to cost me a small fortune, a spray gun has now been sourced. Had it in my head that the entry level was way more expensive.
I've been pointed to a local paint specialist as well so I'll drop by there tomorrow and see what they say. Hopefully they should be able to get me set up with some *decent* high build primer and a good chunk of paint. The suggestion has also been made that household primer and gloss (readily available in any colour you like) could also be a viable option. Given the minimal outlay involved there I'm probably going to give that a shot...if it all peels off in a month then so be it.
Tomorrow I absolutely need to throw the lights, number plates back on and remove the masking from the windows and go for a drive. She needs to drive 15 miles to and from FotU on Saturday, and has barely turned a wheel in the last month! So I reckon I need to do a thorough test tomorrow to make sure she's fit to make the journey. The new pulleys have only been round the block a couple of times so far...and they're kinda critical components!
"cockwomble" !!!???
FotU ??
FotU ??
cockwomble: (countable and uncountable, plural cockwombles) (Britain, slang, derogatory) A foolish or obnoxious person.
cockwomble - Wiktionary
https://en.wiktionary.org/wiki/cockwomble
Its basically the same as '****' only it sounds like you've actually put a bit of thought into the insult.....
So I'd really hoped that I'd have time to give the Invacar a proper shakedown prior to the 15 mile trip to a show tomorrow morning. However I ended up with next to no time to do anything car related today.
However I did pick up some paint while I was out running some other errands.
This actually looks a lot closer in person than the camera makes it look. It's also matched to the transmission cover which is slightly lighter than the doors.
Couldn't resist splashing a bit onto the car in the interests of curiousity.
Does show how far off the mark the blue I'd been using actually was.
This was at like 2200 though...so no test drive.
Tomorrow morning will be the first real test, heading over to Buckingham. If things go well, you'll see her at the Festival of the Unexceptional.
If things don't go well, I'll probably be there with a scruffy Mercedes camper instead.
That is starting to look a bit super!
Never had a chance to do an update over the weekend as we've been massively busy, figured folks would want to know what had been going on.
I wanted to get the Invacar to a show on Saturday, 15 miles out of town, having just had the entire drive system in bits. No test run had been possible due to time constraints...so I felt I had two plans open to me. Get up really early and do some gentle testing around the block before heading to the event...or saying "I'm confident in my work" and just running with it.
So I pointed TPA towards Claydon House and cracked the throttle open. This marked the first time I had ever driven her out of town too, in addition to being the drive system test.
Knew I had the van as a backup if anything did go awry. Having booked in to the show ages in advance I was determined to get something there though.
So...did we get there?
Of course we did!
On the way there I was somewhat amusingly stuck behind modern traffic doing 35-40mph all the way there. On the way home however I had a nice clear road...and all I can say is that I'm staggered by how well TPA drives. She's more than happy to cruise at the legal limit. Way happier than you'd expect from a tiny little three wheeler that wasn't even considered a real car when it was launched in 1971. In fact she's far happier sitting at 60mph than several normal cars I've owned from the late 80s. It's honestly startling.
One thing they're well renowned for is being tossed around alarmingly by crosswinds, and Saturday was a pretty windy day. The issue was far less pronounced (even at 70mph on a bit of dual carriageway) than I was expecting...definitely found driving a lot less unnerving than expected. Not sure if that's in some way due to the change from 12" to 10" wheels with wider tyres...but it's definitely nowhere near as bad as expected. The only other one I know in use is on the 12" wheels and the owner has indicated that it's quite scary on a windy day.
No car stuff on Sunday unsurprisingly, courtesy of collecting this idiot who has now officially joined our family.
She seems so far to be settling in fine. In fact far more so than we'd hoped... apparently she hasn't been out for a walk of more than twenty or thirty minutes on a well known route due to her being so easily spooked. Both yesterday and today we've been out for a couple of miles, even including the pet store. Yes she is skittish, but she coped very well given the issues we had been told to expect.
I think she's just thriving on a house where she's sharing with one dog and four doting humans (she's a truly massive cuddlebug) rather than having a few hours of attention a day in a house where there are 30+ dogs...and the associated noise and smell.
Sure there's a caption just waiting for this expression...
Sure that you'll see plenty more of her as time moves on.
While I was at the car show on Saturday I was handed something else new to me, something I've wanted to add to my collection of random old computing technology since 1999 when I first saw one - An Acorn RiscPC.
It's scruffy as anything, is missing the lid, has broken retaining springs for the front drive bays (they all do that) and it won't even run the power on self test, much less actually boot. However it has a few very useful expansion cards fitted.
StrongARM CPU upgrade.
The somewhat legendary 486-PC-on-a-card. This is really handy as it allows you to properly run normal PC software without faffing around with emulation or anything (bearing in mind that the architecture is utterly different to a standard PC of the time), but as it shares the drives, video etc it's a far cheaper and saves a lot of space than having two totally separate machines on your desk.
It also still has a hard drive in (can tell you purely based on the noise at startup that it's a Conner made drive), so will be interesting to see if there's any software from the back in the day left on the drive.
I've been after one of these machines forever...but they rarely come up for sale at reasonable prices as owners when asked if they would part with them tend to respond with "you can have my RiscPC when you pry the mouse from my cold dead hands...". So I'd pretty much given up on finding one.
It does need work though. Though the failure to boot is most likely due to damage caused by this.
I can't see any broken traces yet, but I'd bet one or two are and that oscillator crystal has probably died.
Of course rather than investigate that I simply removed the old battery and cleaned up the residue...and then did the most important thing: Fixed the retaining springs on the flip up covers over the drive bays.
Needs a really good deep clean though.
Of course we did!
So it's been officially too hot to do much here this last couple of days. It was 32C in our lounge at one point today.
I used to love the hot weather in years gone by until I was put on medication which basically turned the acceptable temperature envelope for me down by about 20C. It's a royal pain in the tail in the summer I tell you that. Anything beyond about 25C ambient and I progressively just start to stop functioning.
Think Star has had the right idea, she's spent most of the day as a fluffy little pancake in front of the AC.
The high temperature though has well suited one job: paintwork.
I've made a decision regarding paint. I'm sticking with the light blue Ford colour I've been using (Bermuda Light Blue if you wondered). I just personally prefer it...I realise that the greener shade is probably closer to how it left the factory but I'm not so keen on it and the paint I've had just hasn't gone on well. The Ford colour I can get relatively inexpensively in cellulose (not enamel which I'd got in my head from somewhere), which should spray nicely with the equipment I've got here.
My plan here is to get the car painted all one colour and with a half reasonable shine on it, then I'm going to step back and try to leave the bodywork alone for the most part and just concentrate on using, enjoying and functionally improving the car for a bit. Next year I'll maybe look to get it into a body shop to be properly stripped back to bare fibreglass and to have a couple of my repairs tidied up by someone who actually knows what they're doing.
My trip over to the Festival of the Unexceptional was quite a revealing experience for me, being the first properly real drive in the car rather than just trundling around town. That showed me how well she actually drives...even with a drive belt in need of adjustment, a thoroughly bodged throttle cable and more rattles than you can shake a stick at. Oh, and a carb which periodically still plays up for a few seconds now and then.
I'm really looking forward to getting some proper miles covered and un-bodging some of my bodges.
For now though I figured that taking advantage of the warm weather to get a few bits painted made sense. Figured I still had about enough paint in stock to get the engine cover done before I go to get my next stock of paint in next week.
The engine cover aside from a bit of pitting in a few places wasn't all that bad and I figured would look all right with fresh paint on.
Didn't come out half bad actually.
Annoyingly I did get one run when my concentration wandered at one point. Luckily it will be covered by the number plate, so I'm not too worried about it.
The lock is also totally seized so will need to be changed which is why I didn't bother masking it off.
I quite like the fact that some of the surface fractures are still visible through the paint as I think it suits the honesty of the appearance of the car.
Given the weather forecast for tomorrow I can't see me leaving the house to be honest!
Really quick update to dump most of the photos taken during (and at a gathering after) the Festival of the Unexceptional a few days back... I've not seen these on an actual computer display yet, so apologies if any editing is still required.
These are in no particular order and probably covers about ten percent of which cars were there...there must have been at least a few hundred motors in attendance.
Only saw one Lada there (Niva) which I appear to have forgotten to photograph...shame!
