Music to test the system required
- Jonno
- Diamond with extra bling
I need a music compilation to test a music sysem, from those elusive highs to the deep, ear bleeding, pressure wave super bass notes.
I intend to fit a kenwood system to the Niva, it has pre-outs at the rear of the head unit and it has a multichanger too.
What would you lot reccommend as a sub for the system? I have a couple of 6x9 Pro Audio 300w 4 ways to fit in the rear somewhere as basic speakers for the system. But I need a bit of "input" (pardon the pun) from those of you who know about this sort of thing.
Lukey, when you come over I want another look at that system of yours mate. I also want to put a recording of AC/DC 'For Those About To Rock' and Rogue Traders 'Voodoo Child' to max out your sub through it
If it doesn't work - hit it with a hammer. If that doesn't work get a bigger hammer.
'95 Hussar
'95 Hussar
ive got some mp3's that are heavily bassed. some which are used to test systems and some which are just songs like prodigy charly (trip in to drum and bass version) theres a bit half way through the song where it says 'charly says.... bass' and theres a very slow rythmic bass note. great for testing bass.
other than that i would suggest using powerfull classical music to check out the whole system with the full range. Try Tchaikovsky-'1812', or holst - mars...
cheers
fin
cheers
fin
- Jonno
Thanks Fin, Classical may be the way to go to give the old jukebox a decent workout. I enjoy most things from Mozart to Metallica. lol
I shall have a look out for Prodigy - Charly
(Did you know the old information films on tv where Charly the cat would meeow his warnings of talking to strangers etc was voiced by Kenny Everett?) Just a bit of useless info there, if anybody wants to know
You really think they provide any usefull information whatsover on anything???!!!! They don't. I'm ashamed to say but I had to buy a copy once so I knowflytedsamara wrote:For recomendations on sound systems (if you're brave) you might want to try buying one of the younger car modifier's mags? Max Factor or something??
Jonno.... I just use a 1200 watt Vibe sub enclosure with intergrated amp. It's 15inch and sounds grrrreat!!!
Before that i used a jbl 1300 amp with 10 inch sub and it did struggle a little.
Power caps can be used and double subs, vented enclosures etc etc... it all depends how much you want to spend and how much rust holds the niva together!!!!
My two favourite pieces for testing a setup like that actually come from the soundtrack to the Lord of the Rings: Return of the King.
The tracks in question being "The White Tree" and "Minas Tirith" - very "big" instrumental tracks. Okay...will rephrase that...absolutely bloody HUGE instrumental tracks!
These two are responsible for quite a few things having "walked" off shelves in this room before when I've had the volume cranked up!
- Jonno
Thanks for the tracks Fin, downloaded and burnt onto CDfindlay234 wrote: ive got a couple of songs called speaker testers and bass testers etc. if you want an email with a couple in then let me know
Now that cleared the earwax out mate !!!!!!! It made the dog cower in the corner, next doors dog is going mental, cats have gone awol, I had to remove the glass lampshades from the wall lights and things started to move on the shelves.
Whether I dare play something like that at full chat in the old motor when I get the sound system installed is another thing. You would have to have a window open wouldn't you otherwise I reckon your head would implode.
I like quite a few of Prodigy's stuff, don't know whether I would go and physically buy those tracks but it certainly gives the sysyem a deep workout on the home hi-fi - Sony S.A.W bass generating system.
Another good suggestion there David with Chris Rea.
I always find good old PF's Shine on you Crazy Diamond a good all round audio test.
Chem Bros Bass Test happens to be, er, backed up up here: http://www.freewebs.com/poppinpixe/Chemical.mid but it's probably actually a bit average for a decent bass test.
Now here's the best track to test bass:
http://www.basscd.com/content/mp3/BassC ... -Track.mp3
Should give your audio - and anything not bolted down - a good work out.
