linux - video editing
Post by excossack » Sun Jun 16, 2013 4:30 pm
Does anyone run Linux and do video editing ? If so, what software do you use?
What I would like to do, is get the video from the camcorder via Firewire and then edit/burn to DVDt
smugsie
Video editing - get Ubuntu first
Post by smugsie » Fri Jun 28, 2013 10:37 am
You need to get the latest version of Ubuntu which is the Linux equivalent to MS Windows but superior on your computer first.
Here is the link: http://www.ubuntu.com/download You can do a test install without commitment so you see how it works.
It is a fantastic operating system and is totally free and any software you download is free plus none of it is advert driven and is a very secure and safe system to use.
You will be able once downloaded and installed to download from the Ubuntu software page plenty of video and photographic software and many other software packages all FREE.
Hope this helps and good luck - Regards Smugsie
Re: linux - video editing
Post by excossack » Fri Jun 28, 2013 12:15 pm
I have downloaded UbuntuStudio and got it installed on a spare machine (Athlon 1.5ghz, 2gb Ram 1x60gb 1x40gb 1x500gb HD)
Just downloaded 241 updates, so need to spend some time getting things setup and see if I can get the Firewire card going, cd burner etc.
smugsie
Post by smugsie » Fri Jun 28, 2013 10:37 pm
The thing about Ubuntu is it does like to keep you up to date hence all the download. You can stop them from happening if you wish.
What do you think of its outward appearance.
You should once you get your head around it be a convertee.
Thank you for trying my advice.
I have had so much help from this forum in general, there are great lads and lassies behind the scenes.
Post by excossack » Sat Jun 29, 2013 7:10 pm
It will take me a while to get used to it. It seems a bit slow at the mo, maybe some tweaks will help.
Still have to install things like Flash player for YouTube etc.
Will see how it goes...
smugsie
Post by smugsie » Sat Jun 29, 2013 7:53 pm
Don't give up. It might be slow if your using an old spec computer.
Post by excossack » Sat Jun 29, 2013 8:09 pm
Spec is Athlon 1.5ghz, 2gb Ram 1x60gb 1x40gb 1x500gb HD
I think work would miss the server with 2 AMD x cores and 32gb Ram....
