Im posting this for a mate of mine.
He has recently bought a nissan terrano2 2.7tdi swb.Problem being it wont engage fourwheel drive at the front wheels it has automatic hubs.When you select fourwheel hi;lo on the transfer box everything seems to be working that end.Anybody able to shed some light on it.
Cheers Gav
Nissan terrano help
Re: Nissan terrano help
Lack of use? Is the linkage working?
I think I have a PDF manual for that engine if that's any help?
Hi John
I suspected lack of use however i know nothing at all regarding the setup on the terrano.
If you could send the pdf manual that would be brillant my email is gavin@dndmaintenance.co.uk
Cheers Gav
Cheers Gav
Hi guys
Thanks for the info.bit of an update took the terrano out and used four low and drive it like that and now the hubs are engaging.However when it goes back in two high there seems to be a grinding type of noise from the front end.He reversed back a few meters when it was taken out of four low however when he doesnt reverse back after using four low there is no grinding noise.
PS simon what sort of a job would it be to do a winch bumper on a terrano..
Cheers Gav
Cheers Gav
Cheers Si going to get the hubs stripped cleaned and greased as you suggested hopefully that will solve and futher issues.
I will let him know about the winch bumper
Cheers Gav
Cheers Gav
