Just after some basic dos and donts for if I was to offer to tow a car out of the snow.
Im not talking about cars stuck in ditches etc, just those that cant get traction or are on slight inclines.
Should I get a tow rope or Chain?
Am I ok to use my tow bar?
I know a number of americans who insist on using chains arround the rear axle. Is this a good idea?
As always thank you for your help. I have done a bit of research on this, but cant find anything specific for the lada.
Towing a car out of the snow
Jeep Wrangler jl 2019
Re: Towing a car out of the snow
Make sure your shackels and tow strops are rated all mine are rated.
Tow balls are ok to use but put a large shackel over the ball itself even safer if you have a ball and pin setup.Best way is a bridle strop fixed to fixed recovery points safest way anyhow..
If you've got traction thats a bonus no point trying to pull anything if you cant get traction even if you have to use a long strop to get on hard standing it doesnt matter..
Hope thats of some help to you
Cheers Gav
Cheers Gav
Cheers mate very helpful.
Now for the cheeky bit. Can you recommend any suitable equipment? I dont want to be spending a fortune at the moment as all this is just incase, but want to make sure I get stuff that is suitable.
I am how ever hoping when I have a bit more free time to join the yorkshire 4x4 response (which I notice your a member of) so anything that will be suitable for that would be a bonus/
Would something like this be suitable?
http://www.ebay.co.uk/itm/3-METRE-4-TON ... 1c221e3072
edit, just been google bridal strap, and that will have to be something for the future when I get 2 tow points
Hi mate i use 19mm green pin shackels about £6 EACH but they are rated.The strop in the link you posted is pefectly ok for what you need just the shackels arent rated.If there is a machine mart close to you the sell strops rated at 5tons for about £12.
http://www.famousfour.co.uk/foursport/shackles.php
Also if you are unsure what a strop is rated at you can tell by how many rows of stiching there is across the strop.IE 3 rows of stich equals 3 ton rated strop
Well worth joining yorks lincs 4x4 response loads of training etc going on plus it will be nice to see another niva..
Cheers Gav
Cheers Gav
Thank you for all the advice. I'll nip to machine mart on monday.
Thank you again
Thank you again
