by GadgetBoy » Fri Jun 17, 2011 8:26 pm
Because all of the above has been done John.
- Titanium with furry dice
by excossack » Fri Jun 17, 2011 8:33 pm
I didn't know you'd checked the heads
A long shot. Would you see the slipped liners with something like this?
http://cgi.ebay.co.uk/USB-ENDOSCOPE-BOR ... 4aa7be9888
and poke it into each cylinder?
by GadgetBoy » Fri Jun 17, 2011 8:40 pm
There are two problems with that .....
1. Most of the low cost endoscopes have a 14mm head which won't find a standard plug 'ole (14mm diameter to thread depth)
2. When you get one that fits you then have to turn the head at 90 degrees immediately. This isn't possible.
Believe me .... I've researched/diagnosed/scratched my backside thoroughly with this one John but I appreciate the suggestions.
by excossack » Fri Jun 17, 2011 8:42 pm
ah well. Out with the spanners and out with the engine....Could you see the liners by removing the sump?
Just chucking ideas into the mix with some thinking outside the box
by GadgetBoy » Fri Jun 17, 2011 8:45 pm
I'm not worried about the current engine and its pesky liners. I have a new low mileage short block that I'll rebuild on the bench first and then do a transplant job.
Gonna try the Steel Seal first though.
by excossack » Fri Jun 17, 2011 8:50 pm
Go for it then.
I tried K-Seal in the Landy and it stopped the leak for 2 months and then it started leaking again, so I ended up with a new head....£1200+
by GadgetBoy » Fri Jun 17, 2011 9:10 pm
Oops!
As I said before - I know exactly where I stand with this engine so I've got nothing to lose.
by excossack » Fri Jun 17, 2011 9:20 pm
and the £1200 didnt include the rest of the work!
as you've said, nothing to lose.
What you going to do with the old engine, rebuild or turn into a coffee table for the new office with some lighting in each cylinder?
by GadgetBoy » Fri Jun 17, 2011 9:32 pm
That's an idea John. It's a beautiful casting and it has a perfectly flat and square cast sump too.
Little motor on the starter ring to make the pistons go up and down.
I like that idea.
Gunsnlada
by Gunsnlada » Sat Jun 18, 2011 12:23 am
Stop by your nearest toyota dealer.. ask them for a few litters of their Pink coolant...when leaking ill turn solid and bright pink...usually pretty easy to see
Chevy Silverado '89 305
Lada Niva '96 1.7i
Lada Cossaq '98 1.7i
Chevy cavalier '99 3.4lv6 to be supercharged
by GadgetBoy » Sat Jun 18, 2011 7:15 am
There's already "Pink" coolant (OAT) in it.
by excossack » Fri Jun 24, 2011 8:30 pm
Have you had any further progress on the KV6 ?
by GadgetBoy » Fri Jun 24, 2011 8:31 pm
Doing the Steel Seal tomorrow. Arrived today. Looks like fluorescent wee.
by excossack » Fri Jun 24, 2011 8:39 pm
Nice.....I tried(the garage) some aircon leak detecting fluid in the coolant system on the Landy to try and trace the leak, but it was internal.
Does this SS stuff glow under UV light ?
by GadgetBoy » Fri Jun 24, 2011 8:56 pm
I'll find out for you. I have UV sources up in the office.
