KV6: The Coolant Chronicles.
In order to try and find a persistent coolant leak I've done a lot of work on my car recently including:
Thermostat and associated pipes replaced
Inlet manifold gaskets replaced
Inlet chamber seals and o-rings (nothing to do with coolant but I was there)
Water pump replaced
Timing belts and associated twiddly things (again not coolant related but I was there)
New plugs (those back 3 are a lot easier with all the gubbins out of the road)
All coolant plumbing/hoses have been checked
New expansion tank cap
Heater matrix inspected
Radiator inspected
As a result I've found out I have a factory replacement engine and some buggr's had me oil cooler!
With all the work done the engine is running beautifully. Smoother, more responsive, noticeably more get up and go and improved fuel consumption. You would think it has just left the production line.
And .........
STILL losing coolant!
Not a lot but a measureable amount every day. The following table/chart details:
As you can see the mileage has little relationship to the amount of coolant lost. My driving style has been consistent. It would appear the coolant loss is random but I'm convinced more is lost when the A/C is on (clue?).
I do, however, now know where the coolant is going ....... into the oil.
There is absolutely no evidence of head gasket(s) failure so I have come to the sad conclusion I have a liner problem.
I have the advantage of a second car (needs MOT'd but that ain't a problem) and I've sourced a short block for very little money. So, before I whip the engine out has anyone got any bright ideas?
Water pump replaced
Radiator inspected
And .........
Ive just found your post on www.the75andztclub.co.uk/
Worth a try...
Worth a try...
dunno if you know Rover had an issue with porose castings with everything from blocks..heads...manifolds the lot also the machine faces never ran flat ..drilled holes went to deep into water jackets ....blame Paymaster General Geoffrey Robinson skimmed off the workers pensions so noone gave a monkeys and built rubbish basicaly ...i lost my job as a result of his skimming .....just a thought that was all
I'm fully aware of Rover's history and the problems they had. My car is a 2002 car when Rover were just about as healthy as they ever were.
Time will tell where the problem really is when I strip the engine but I'm pretty certain it's a liner issue. While not a common problem it is a known issue with the KV6.
Apart from the engine issue it's a beautiful car. Absolute top of the range with pretty much every option there is. It drives beautifully and wafts along with the sort of ride you would normally expect from a Bentley. The V6 is an absolute peach of an engine. Never fails to turn heads when I give it the loud pedal and will still pootle around when I'm in pipe and slippers mode.
Gadgy, Does it lose colant when stood still?
If it is doing it under pressure/ running conditions there MIGHT be an issue if there are studs that protrode into the water jacket (manifold ect) that also breach the oilways or the sump / crankcase.
Total shot in the dark bu the FIAT TC lump looses oil from the cambox via the studs if not correctly built.
2000 to 2001 all the fubard parts were cast and machined and sent to rover/ford/jaguar/smart as thats when we found out about our pensions if the fault is say a tap hole/crack/porose into the exhaust or inlet ways you will never find it ....i have in the past to find leaks put ribena in the water system then park it over some white paper towel just to get a rough idea even if you cant see any drips on the engine the paper will show where to look up at then follow where you think the route it may of taken as leaks rarley just come down
The liners go in from the crank end and are shouldered. They're glued in with Hylomar and if there hasn't been enough applied they can slip down.
I'm going to try Steel Seal in it because a number of KV6 engine owners have had the same problem and Steel Seal has sorted it. Normally I'd boil anyone who uses Steel Seal (or K-Seal) in oil but I've got nothing to lose. As it stands at the moment it's fecked.
It's Steel Seal or a rebuild.
