Guess what I'm doing this weekend .....
Yes Simon. The actual timing belt bit is fairly straightforward, It's the taking everything off to get at them and then putting it all back that's the slow bit.
Donald. Absolute peach of an engine. Doesn't suffer from the K16 HGF. Goes like stink and the sound is wonderful. Galvanised body too so they don't rust. Good motor.
Not necessary. But ......
Air box
Battery and battery box
Inlet chamber
Alternator
Compressor (move to one side)
PS Pump (move to one side)
Dipstick tube (drain oil first)
RH Engine mount (support engine)
Offside front wheel
Wheel arch liner
Crank pulley
Outer cover
Inner cover (3 bits)
Rear rear bank cam sprocket covers
Rear front bank cam sprocket covers
Drain coolant
Then ........ you can do the belts
Air box
Inlet chamber
Alternator
Offside front wheel
Wheel arch liner
Crank pulley
Outer cover
Drain coolant
Two things John.
1. By the looks of the old belts they had been done not long before I got the car although the idler was completely fubared. I suspect it hadn't been changed - somebody taking a shortcut.
2. It had been done by a baboon with his torque wrench set to 1'000'000'000NM. I had to use a pry bar to get virtually every nut and bolt undone.
Apart from that it's straightforward but the amount of stuff you have to remove to get at the belts is nothing ordinary. Very, very time consuming.
I cannot help but get the impression that ease of service access wasn't something the designers had in mind when they A: Designed the engine, and B: Shoe-horned it into that engine bay!
Is this the same lump they used in the V6 800s? Remember we had one of them in at the garage a while back and I remember being utterly gobsmacked at what a lovely thing it was to drive. Sounded loooovely and didn't half shift.
