Kangoo Heater Problem(s)
So the Kangoo has a heater problem.
Its either one thing or two or three depending on other things.
Anyway, the heater only blows on speed 4, nothing on 1,2,3. So unscrewed the 4 torx headed screws and had a look at the switch.
Upon removing the 6 pin connector I found one of the pins had melted and moved slightly so causing a loose connection. So both the switch and the connector are burnt.
Now the switch panel itself is avaible on ebay (maybe even new) but I cant find a 6 pin connector for it.
I could just find the wires that run the fan and have it connected to a on/off switch so its either on full power or off.
But before I do that, are their any websites where I will find a renault 6 pin connector for sale other than dealer?
1.7i, White. Sadly for sale.
One of these panels?
http://cgi.ebay.co.uk/1999-RENAULT-KANG ... 0527153107
Ive used parts gateway service to find parts from breakers around the country
http://www.partsgateway.co.uk/
