"Lumpy" idle - Fiat Panda
Post by Zelandeth » Sat Nov 06, 2010 7:55 pm
This isn't mine - but a friend's asked me to look into the issue for him.
He's got a Panda (proper one! - 1993 L plate 1000 Fire in a lovely metallic green colour) which refuses to idle smoothly.
It sounds like one cylinder is missing every 5 or so revolutions of the engine - quite regularly. Once you pick the revs up at all it's fine, and it drives like the day it left the factory with the exception of 3rd gear only having syncromesh when it feels like it. It pulls perfectly smoothly right through the rev band.
I'm not convinced there's actually anything wrong here - we've had two Pandas, and they've both done this from the day we got them to the day they were sold on - however it does sound like something that's indicative of a fault, as I remember replacing half the ignition system on our last one to try to get it to tick over smoothly.
Mixture looks to be perfect as it passed its MOT only a few weeks ago and everything there looks perfect.
I know we've got at least one person here who knows Pandas - so hoping someone can confirm whether this is just a quirk or not.
...Downside of having a shot of it is that it's reminded me what fun little cars they are to drive! Few things rev like a small Fiat engine, and in a light car like that they can really shift! Yes, they're a tin box with wheels...but they're just one of those cars I think which manage to be more than the sum of their parts, and I like 'em.
*sigh* Guess that's another one to add to the "Actually I'd like one of these..." list!
Post by GadgetBoy » Sat Nov 06, 2010 8:01 pm
What's the age of the timing belt?
Post by Zelandeth » Sat Nov 06, 2010 8:09 pm
I'll need to ask - but I seem to recall that most service items were changed when he got the car as a precaution a year or so back.
How frequently are they meant to be changed on those engines for that matter? Never even looked at the belt on either of ours.
...Granted, I knew a heck of a lot less about cars back then!
Post by GadgetBoy » Sat Nov 06, 2010 8:17 pm
Can't remember myself and my Panda was pre-Fire. I know a sloppy timing belt will cause issues.
Donald (NitroWarrior) is the Panda man.
Post by Zelandeth » Sun Nov 07, 2010 8:23 pm
Hmm, our last one ran like that for about three years I think!
It's perfect anything above idle - just when idling naturally that it does it.
Haven't had any response to my query about the age of the t/belt yet, will report back once I have that information.
Post by excossack » Sun Nov 07, 2010 8:24 pm
Air leak on the carb?
failing plugs?
failing leads?
distributer issues?
Post by Zelandeth » Tue Nov 09, 2010 9:35 pm
Okay, heard back today. Timing belt was changed shortly after he got the car just under a year ago. It did this before and after the belt was changed.
Plugs and HT leads are also pretty new - IF my memory serves me correctly, this doesn't have a distributor cap, instead using a coil-pack similar to the injected Nivas - I could be wrong there so will need to check next time I'm under the bonnet. I do remember that the plugs which came out looked exactly as they should do.
No carb to worry about on this one as it's injected (similar setup to the Niva - single point injection). No check engine light (well...the warning light with the indecypherable symbol on it which I assume to be the check engine light!) has cropped up or anything. Comes on with the ignition and vanishes a moment after the engine starts.
I'll take a can of carb cleaner with me next time I go near the car and have a hunt for vacuum leaks - but I don't think I'm going to find any.
The more I think about this and how our L plate one (pictured, which I miss - even though the interior was painfully green!) ran the more I think that this might just be a bit of a quirk of the idle control system modulating the fuel supply in the interests of economy. You really can't notice it from inside the car unless you're looking for it - standing next to the tailpipe being the only place that it's really obvious! There's not exactly an excess of silencing on these cars exhausts either, which probably makes it more obvious.
Makes me realise as well, these photos must have been quite early ones when we had the car...Shortly after that I found one in a scrapper with a clock and illuminated heater controls and switched those out - and added illumination to the switchgear (fibre optic unit bagged from an Uno), and added a red hazard light switch cap from a Cinqueccento. ...Oh to have time to mess around with details like that again!
Post by excossack » Tue Nov 09, 2010 9:41 pm
Coil pack breaking down? In the garage, we have a 1300cc Uno, and that had a coil pack, on closer inspection one of the wires had started breaking down, and inside the disy is an magnetic pickup, and these wires had also broken down.
