leaking radiator - how bad is the stop leak stuff?
skelter
Post by skelter » Thu Sep 09, 2010 7:45 pm
I noticed coolant leaking from the radiator, about a drip per 2 seconds (hot engine while running), from the bottom part, just below the grill-area. All hoses, rest of radiator and the engine are dry.
I searched for a radiator-specialist, but the closest one I could find is over an hour away... I'll ask around, but there is not much going on in my area, so I doubt I'll find one closer to me.
So... The stop-leak stuff, how bad is it, does it even work? What if I use it, and immediately flush out the coolant and replace it?
'87 Niva - Skelter V (onroad)
Deutz D5207 (offroad)
Post by GadgetBoy » Thu Sep 09, 2010 7:58 pm
Radiator leak stop should be avoided at all costs. Only use it if you've got absolutely no choice.
Check with local places that repair trucks. They'll usually be able to do simple radiator stuff or know someone who can.
Eddy
Post by Eddy » Fri Sep 10, 2010 4:49 am
for emergency ... 2-3 teaspoons of pepper does the job
"Kremlin Gremlin" '85 Lada Niva, weber, 33x10.5r15, 4" lift, rust,dents.
'78 Leyland Terrier V8 ... TRUCK
No rank
Post by Hoodoo » Fri Sep 10, 2010 5:54 pm
Can you take the rad out and solder it yourself?
skelter
Post by skelter » Fri Sep 10, 2010 7:20 pm
Hoodoo wrote:Can you take the rad out and solder it yourself?
Funny, because that's what I just did :D
I just got back from taking the Niva for a short trip after doing some soldering on the radiator and so far it seems to be holding up!
I noticed a tiny crack/fracture just below the edge that sticks out (a few mms) just below the grill-area. It was real easy to solder with the rad upside down.
mooshaker
Silver
Silver
Post by mooshaker » Fri Sep 10, 2010 11:10 pm
that stuff you add to the rad buggered my water pump up costing 4 x what a rad would of cost to replace in the first place lol
skelter
Re: leaking radiator - how bad is the stop leak stuff?
Post by skelter » Thu Oct 21, 2010 6:06 pm
skelter wrote:So... The stop-leak stuff, how bad is it, does it even work?
I can answer my own question after replacing the stuck heater valve...
I guess the "mechanic" I bought the Niva from used it to fix the radiator :(
I will flush the system thoroughly and put new coolant in, hopefully that will get rid of all the gunk!
