KV6: The Coolant Chronicles.
Day 1
Day 1
Today was the first day after the full SteelSeal treatment process.
This morning the car required a tiny amount of coolant to bring it to the Max mark. Perhaps 20ml, certainly no more.
The most interesting thing was there was neither positive nor negative pressure when I opened the header tank.
I checked the car this evening after a run where I know I would lose maybe 100ml of coolant and nothing! Coolant level spot on.
SteelSeal has definitely had some effect.
Day 3
Day 3
June the 29th, 2011, was much like any other summer's day in Belfast, and GadgetBoy, a renegade IT Consultant, was on his way to work as usual when ....... Nothing happened! Scarcely able to believe his eyes, GadgetBoy looked down. But one glance confirmed his suspicions. Behind a bush, on the side of the road, there was no severed arm. No dismembered trunk of a man in his late fifties. No head in a bag. Nothing. Not a sausage. For GadgetBoy, this was not to be the start of any trail of events which would not, in no time at all, involve him in neither a tangled knot of suspicion, nor any web of lies, which would, had he been not involved, surely have led him to no other place, than the central criminal court of the Old Bailey.
And no coolant loss either.
Day 4
Day 4
Yet another day of nothing to report. Peeked in the expansion tank this morning and I must admit I'm now expecting to see the coolant at the right level. I wasn't wrong.
So I suppose now we have to have the discussion on Steel Seal (other products are available).
All I can say for now is Steel Seal has stopped me losing coolant and therefore it does what it says on the tin (well plastic bottle).
As I've said before I've never been a fan of products like this nor am I now but let's look at this from a different angle. I'm not trying to bodge a blown head gasket or cracked head. I'm trying to correct a problem which I suspect is down to failed sealant. The liners in the KV6 are sealed with Hylomar and it would appear there has been a failure of this Hylomar seal in my car. All I'm try to do is repair that seal without major engine out work. Steel Seal appears to have done that for me and I laud it for that.
The one thing I have concerns about is the longevity of the "fix". Theoretically, if another liner issue occurs the Steel Seal already in the coolant should seal that as well. Likewise if the current "fix" fails the Steel Seal should self-repair so as to speak.
I'm interested to hear anybody else's views.
I had similar done to my LR. It did the trick for a month or two and then coolant started to drop again.
So yes it can work and in some cases it will be a permanent fix, but I suppose each case is different.
Keep an eye on it as your doing just in case. Worse case its engine out time.
You could however consider getting a spare block, cleaning it all up and maybe start to acquire parts to do the swap or even build a complete engine on the bench.
Days 5 - 8
Days 5 - 8
Not a huge amount to report.
Except Saturday
On Saturday morning I had to put 40 -50ml of coolant in. Shock, horror, doom and despair!
But - Friday was a warm day and I had the A/C on. I deliberately left the A/C off Saturday and Sunday and no coolant loss at all.
So what's the link between the A/C and the cooling system?
Except Saturday
No idea...
Assuming that the condenser is a separate unit on that as with most cars rather than being incorporated into the radiator or something crazy?
Additional load on the belts making the...wait...water pump is driven by timing belt...never mind.
Really have no idea!
Clutching at straws, leak from one of the heater hoses/control valve when it's set to cold? Assuming it even has a heater control valve rather than just the flappy things many cars seem to.
Really don't know...though I would love to find out what's going on.
