Post by excossack » Fri Feb 24, 2012 9:33 pm
Post by excossack » Sat Feb 25, 2012 8:41 am
Maybe not those exact ones. but a set of those types
Post by excossack » Sat Feb 25, 2012 8:51 am
I'm not awake yet. Got woken up by the Mrs going to work and telling me there was no hot water and the heating wasn't on. this was 4am....
The boiler inst firing up. It tries and fails... :-( little flashing light that looks like an egg timer
Well that's my excuse for falling for your cunning ploy
Post by excossack » Sat Feb 25, 2012 9:09 am
I have heard they are.
Gas boiler
Around 1999
Made by Vaillant
Model number TurboMax VUW GB 242/1 E
Post by excossack » Sat Feb 25, 2012 9:17 am
We have gas to the house, that Ive tested. So I assume that gas is getting to the boiler OK.
So its over to a gas Eng, to sort it out. :-(
RickG
Post by RickG » Sat Feb 25, 2012 1:10 pm
John:
Would not hurt to check your air intake for the boiler, had a friend get the specialist out just to find that the intake under her deck was plugged. I would imagine the board checks for airflow on startup.
nivafan
Post by nivafan » Sat Feb 25, 2012 2:13 pm
Today I delivered some urgent Niva parts to Justincase in Iceland! Nice to meet you Eric.
Nivafan
1.7i
Post by excossack » Sat Feb 25, 2012 5:56 pm
Ive tried a reset option, well turning it off and back on again. Air intake is at the top the house so need a long set of ladders to check.
I've made a call to a women I used to work with who is now a plumber/gas fitter and she is turning up tomorrow to have a look....so will see then
Post by excossack » Sun Feb 26, 2012 8:47 am
No error codes just a flashing hour glass type light. Will see if i can get a picture
Post by excossack » Sun Feb 26, 2012 8:51 am
Here we are. 3rd light from the top
boiler lights-web.jpg (90.39 KiB) Viewed 17984 times
Post by Tom. » Sun Feb 26, 2012 9:17 am
John thats the gas valve open symbol and it indicates low pressure in the system. Check your pressure gauge and top up via your filling loop to 1.5 bar. Should do the trick.
Post by excossack » Sun Feb 26, 2012 10:17 am
Cheers Tom. The pressure gauge is showing 1 bar. I'm sure the pressure used to be sitting at around 1.5 bar
Is that the pressure for CH water, or the incoming water pressure or is the pressure overall?
No OBD socket :-(
Post by excossack » Sun Feb 26, 2012 8:21 pm
Had fun and games with the boiler. With help from Tom (Uzbek) it sprang into life just as the boiler eng arrived. Many thanks to Tom for his assistance.
Post by excossack » Mon Feb 27, 2012 8:27 pm
Went shopping with a friend, and came back with a PTO powered circular saw (28" blade), 5 plastic barrels (FOC), some stainless door bolts for the Landy and a transfercase output shaft seal.
Post by excossack » Mon Feb 27, 2012 8:53 pm
Certainly is!
and then we spotted one of these in a local trailer hire place
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... ink:top:en
