Merc around a 2006 plate, Not sure on the Class.
Nope.
Merc hunting refers to when I took the Landy to work covered in mud and parked it next to one of the clean shinning Merc that belonged to one of the project managers....The comment refereed to me not washing the car before bringing it to work and parking it in the car park.
So I left it dirty for the week
.....and to prove a point
Busy is good! Glad to hear it, and hope it carries on!
Must see you sometime about some tree sliders that follow the roof gutters. Just front to rear, then bolted through the roof onto the roll cage.
It is. Especially with the sun on it.
Changed the thermostat. On Sunday, coming off the lanes, I became convinced the Niva was running cooler than normal; in fact, a long downhill run on engine braking, resulted in the 'check engine' light coming on and the scanner indicating a faulty Lambda sensor amongst other things! And I'm positive that running cooler was what caused it.
A call to Neil on Monday, saw a new unit delivered today. Excellent service - thanks Neil!
The valve assembly in the old 'stat could be pushed open under finger pressure. This could not be done to the new one, which means I was right!
New one fitted and car now running fine.
Old 'stat lasted 8.5 years, which I reckon isn't too bad!
Yesterday was WRC time. So spent the day in a forest in North Wales. First victim was a transit van driver that had slipped off the muddy/slippy/wet/gravel track and ended up with both N/S wheels in a small ditch.
Quick tug with a rope and a Land Rover soon had him out.
Then into stage. 1st car went past at 16:18 and then after that it was darkness and a blur of headlamps.
- wrc nov 2011 002-web.jpg (83.37 KiB) Viewed 19440 times
- wrc nov 2011 001-web.jpg (70.2 KiB) Viewed 19440 times
And you've STILL not washed it!
Figured you'd be on the Rally!
Its had a jet wash down at the local jet wash. Clumps of mud on the floor.
Now it needs a wash and a polish as well as a 2nd go on the underneath with a jetwash.
Today i found a set of GoodYear Wrangler LT245/75R16 that seem to fit almost perfectly on my lada.... the barely rub on the coil tower.... and the best ..... there free
.. i may (very probably ) have to do a bit of trimming on the fenders...
Chevy Silverado '89 305
Lada Niva '96 1.7i
Lada Cossaq '98 1.7i
Chevy cavalier '99 3.4lv6 to be supercharged
Lada Niva '96 1.7i
fitted a set of spring and shock spacers to a friends new Jimny, and took it for a quick tester on some local lanes:
and since we're on a lada forum, a couple of mine doing its thing!
rob
rob
skids, if carried out correctly, are not just for kids...
Boring people will always try to make you feel stupid.
Go big or go home.
BlandRover discovery, 200tdi. Don't hold it against me.
Go big or go home.
Cooked a roast dinner (chicken, roast spuds, Yorkshire puddings. All in a lazy day really.
