Finally got around to sorting something today on TPA which has been making my teeth itch for over a year now.
Spot the difference.
(Aside from the distributor cap.)
Yes... finally dealt with this horrific bodgefest.
These are the original battery hold downs. Sadly as I was completely unable to find the original form factor battery (or indeed what type it even was), they're basically useless.
Oh, and here's a reminder why bungee cords and cable ties are not a permanent solution.
That had been pinched between the rear wheel tub and the chassis rail and had rubbed about 2/3rds of the way through.
My solution has been to cut a couple of bits of M8 threaded rod to roughly the right length (a little over 6") and fasten a bit of webbing between them - this is a bit of seatbelt originally from KPL I think where the buckles had completely rotted away to nothing.
I heated a metal rod up to red hot before using it as a punch to make two holes. This melts the fibres together and prevents anything from fraying.
Not too worried about that anyway. Ever tried to tear a seatbelt, even if it's already frayed halfway through?
Finished article...
It's tightened up sufficiently that the battery is completely secure. If I have issues with it ovalling the holes out I'll replace it with a strip of angled steel instead - but I'd really rather avoid the need for metal across the top of the battery if I can avoid it given the layout. I might go back and bolt a lip onto the tray though just so there's then *absolutely* no way it could conceivably slide free then. It can't go anywhere the other direction as the wheel tub is in the way. Probably overkill...but I'm a fan of doing what I can to keep Murphy's Law at bay. It's really not a heavy battery either, probably half the weight of your average car one.
I had someone ask me on another forum what the labels on the slam panel were all about - the answer is "me getting fed up of realising I need to consult the manual in the middle of a service one time too many."
Couple of photos from while she was out in the sun today just for good measure too.
Really need to remember to paint that rear wheel arch...I just can't see it from in the garage so keep forgetting there are still white filler spots visible there.
Noticed I've got a drip from the sump plug... that's what I get for being a cheapskate and not just replacing the copper washer (which I noted was well mangled originally). No idea why I didn't just change it given I have them in stock. Oh well...on the plus side at least I'm not dropping a huge amount of oil to change it!
