Aaron
Post by Aaron » Thu May 09, 2019 9:13 am
It always makes me laugh (but not in a good way) when you put a single word search into ebay and it offers you "results matching fewer words".
Peugeot (it's only for towing the caravan) 406 (early 99 thursday afternoon spec)
Post by Zelandeth » Thu May 09, 2019 11:55 pm
I had a spare hour (ish) this afternoon so made another pass at the "clean the secondary pulley game" on the Invacar.
A metre of threaded rod was all of £1.85 from Toolstation. That, a couple of bolts and a few washers allowed me to create this potentially lethal contraption out of my poor innocent workbench and even more horribly abused (yet apparently indestructible) power drill.
It's actually infinitely less terrifying than it looks courtesy of the pulley (as you would expect) being really insanely well balanced. It wobbles a bit at around 500rpm, but then smooths out totally up to the free running speed of the drill. What is scary is that *stopping* from that speed takes the best part of a minute thanks to the rotational inertia involved...
I only did that once though, more out of curiousity as to how well balanced stuff was, while being ready to leg it at a moment's notice.
For reference this is the pulley surface we started with following my first pass at cleaning it with the polycarbide mop on the grinder last week.
An hour or so of working at it with a combination of a chisel (ooooh...sparks!) and several grades of Emery cloth resulted in the surface looking like this.
While there's still a lot of visible tarnish there the pulleys surface is now smooth to the touch across the full running surface. Whether this will help things or not I will hopefully find out tomorrow. It's hard to express quite how much smoother that pulley face feels than it looks in the photo.
Realistically, this is as good as the pulley surface is going to get without being able to throw it onto an actual lathe with a suitable cutter to reface the running surfaces properly. It just ain't going to get any better in my hands...so if it still eats belts I'll probably need to get a machine shop involved.
The last thing I did before packing up this evening was throw (not literally of course) a load of filler at the bodywork.
The area behind the nearside wheelarch should benefit a lot from this (remember, there was a huge crack there). I'll hit it with the sander and some paint tomorrow (or another coat of filler if needed - I'm going for presentable from twenty paces here) to tidy things up a bit. Obviously will be a fair amount more needed, but it's the first time I've used this exact stuff so I wanted to start simple. Plus to be brutally honest I'm more interested in driving this car right now than making it pretty...
Post by Zelandeth » Fri May 10, 2019 10:56 pm
Having had a think about it further this morning I went to confirm the identification of my brake master cylinder so I could get either a service kit or new cylinder ordered.
Nice to see that the fluid level hasn't moved in the slightest since I've started driving it, I know there's no reason it should have, but it's still nice to see the fluid staying where it should be.
Yep, there's the number which I couldn't remember or find written down anywhere.
Doing a bit of digging around on the internet to see what I could find. When did the search function on everything become so utterly useless? Why when I type in "Girling 625 master cylinder service kit" are the first five items for Lockheed cylinders or totally different complete cylinders before anything starts to turn up that's useful?
Anyhow...eventually managed to track down some rebuild kits. They're a good bit more expensive than I'd expected...not far off the same price that genuine Girling cylinders seem to go for (£60 or thereabouts). Though there are a plethora of off brand ones for £20-30 out there. Though quite what sort of quality to expect at that point I'm not sure.
I did however decide to grab one. Basically because A: I've had gift money sitting in my Amazon account for about two years now so it's essentially free. B: Because it will at least let me prove the rest of the system behaves or not. If it does behave perfectly then I at least know that the MC is the issue...if I can't then make one good cylinder out of the two or am actually satisfied with the one from Amazon that turns up, I'll get a proper new Girling one ordered up. As the one I've ordered is essentially free it seemed worth a shot though.
Bodywork wise I've given things over the back a sand down (man I'd forgotten how much dust that creates!) and blew a quick bit of paint over it.
Definitely heading in the right direction... here's the same panel when the car arrived on my driveway.
Will want another coat or three of filler, but we're definitely making progress. I'll make sure I actually have enough on hand next time!
She's never going to be a concourse show winner, but hoping that a finish that's presentable from ten or twenty paces should be doable.
What I was really interested in seeing though was whether my messing about with the CVT secondary pulley yesterday had actually done anything useful.
The answer is a definite yes. While I've only been able to do testing up to 30mph today courtesy of rush hour, things have obviously improved. The pickup from a standing start is smoother and changes to throttle setting are far more quickly responded to now. It's also way quieter.
Have a *really* shaky video showing how things are behaving now. I'll hopefully make a run out onto a faster road tomorrow to see how it behaves.
While I was on Amazon earlier this afternoon a better phone mount was also ordered...so hopefully any future footage recorded on that will be something resembling stable. I can only apologise for how awful the footage here is.
YouTube Video Link
Feels like we're getting quite close to a car which is actually usable now.
Post by Zelandeth » Sat May 11, 2019 11:06 pm
Did a bit of experimentation with my existing camera mount to see if it could be improved while I wait for a better one to turn up...nope. Still shaky as ever...so the video from today is equally as unwatchable as the one from yesterday. If anyone actually wants to see it anyway let me know and I can chuck it at YouTube.
Another 16 miles covered. Was actually tempted to keep going but ran out of time.
The run out today was uneventful. Even if I did utterly confuse the poor folks at the fuel station. Speaking of fuel - average fuel consumption on the first tank (well, about half a tank) was 28.1mpg. Given the fact that during that tank we've had sickly carb, plethora of neglect issues in the CVT and have only left the block on a couple of occasions that's a reasonable starting point. Hoping we can expect to see mid to high 30s.
The CVT is very obviously far, far happier. 50mph cruising is almost comfortable, and the judder when moving off from standing still is very much reduced. Had 60mph on the speedo on a couple of occasions. The other thing which is conspicuously absent now is the smell of burning rubber which had previously accompanied any attempts to venture beyond 40mph or so. Obviously I'll need to get a few more miles on the clock to see if we've got things back into a stable and reliable state.
One thing which was made abundantly clear this afternoon was that not having a sun visor is *really* annoying. I've had the trim panel to which it is attached sitting around waiting to be reinstalled for a couple of months now, but finally got around to putting it back in this evening.
I had hoped to get the control box for the heater and choke out to paint it...however it was utterly unimpressed with that idea, so just gave it a coat of paint the old fashioned way with a brush in situ. Not perfect by any means but is at least a bit less scruffy.
While on the subject of tidying the interior I figured it was time to throw a bit of paint on the handlebars and some rusty bits of the seat frame. This has definitely helped make things look a bit less derelict.
Slightly out of order as this was earlier in the day, but I've also given the offside wheelarch a quick skim over with the paint. It had weathered away here to nothing so even though it's not a perfect colour match or all that smooth, it's still an improvement.
Have picked up a load of filler today too, so will hopefully get a few of the scruffy bits of body sorted this week. At least most of it is small patches rather than outright rebuilding like the rear valance...
While I was playing automotive Tetris to put the Invacar away I snapped this photo.
This is a good one for the "what year was this photo taken?" category I think.
Post by Zelandeth » Mon May 13, 2019 12:26 am
First task for this afternoon was to get again replace the throttle cable on the Lada. Out of everything to do with the injection conversion the throttle linkage has been by far the biggest recurring headache. Today involved quite a significant re-engineering of things. It's not 100% perfect (foot down is about 90% open at the throttle body) but far better, and for the first time since I started the conversion it no longer sticks about 1% open when returning to idle. Has made it way more pleasant to drive. Have to wonder how long it will take me to remember that I don't need to tap the pedal back fully up whenever I come to rest...
Bit of a milestone passed while on the test run.
(Ignore the check engine light. It's a wiring issue to the vehicle speed sensor and doesn't actually affect anything in the real world, just tends to ping the light up if you coast for more than a few seconds).
Feeling optimistic having got that sorted out I thought I'd look into seeing if I could do something about the clutch on the Xantia.
This has been a bit of an issue as long as I've had the car. The clutch works just fine, no judder, no slip no snatching. However the bite point is about an inch from the floor, which gets quite tiresome around town.
Not knowing for certain if there was any way to adjust the cable I figured it would just make sense to find it and have a poke around. I've managed to convince supposedly self adjusting cables to tension up better with a bit of violence before. Now, the engine bay in the Activa is somewhat "busy" to be honest. Nothing obvious there, but I figured it would likely be easy enough if I pulled the air cleaner out.
Hmm...nope. Still can't find it. Let's pull the rest of the air intake elbow and look closer.
Plenty of obvious cables for the gear change...no obvious clutch gubbins. How about taking a look underneath?
Nothing (aside from a minor LHM leak - one of the return line weeps slightly at the reservoir). It looks horrendous in the photo but she's never used a drop of oil, water or LHM and doesn't mark her territory.
Turns out I'm an utter idiot. The Activa in 2.0T form (all we got in the UK) has the ML5 gearbox...which means hydraulic clutch! That had never even crossed my mind...once that gem of information crossed my mind the fact that there must be a fluid reservoir for it (unless it uses LHM...though apparently not) also joined the party. A tip from a fellow Citroen enthusiast has me now knowing where to look. Turns out I'd looked at it a hundred times and never given it a second thought.
I'd always assumed that was the interia switch as that's what it looks like.
So I'll check it there's fluid in it in the morning and see about bleeding it. Fingers crossed that might help a bit as there's no adjustment possible and it's been bugging me this last week (it's the van's fault as the clutch in that is lovely now).
Invacar has been seeing a bit more cosmetic work continue. Bit more filler has been thrown into the equation to help smooth things down before I throw some more paint at it.
Small (but to my mind disproportionately annoying) chunk missing from the offside door.
Top of the nearside front wing where it's had a knock at some point. I'd already applied matting and resin from behind the panel.
Worst panel on the car though was the front service cover, so we'll see how that looks after some sanding action.
Will just be a quick sand and splash tomorrow morning which will make things look a little bit more presentable.
Post by Zelandeth » Mon May 13, 2019 10:24 pm
Had a bit of a special day today as the owner of TWC was due to pay me a visit. His rescue from a field and restoration of TWC was responsible for me discovering what an Invacar was. I'd never heard of them until then. Shortly after wound up with one which was missing a large portion of the bodywork but was generally sound mechanically...then once TWC was back on the road, I bought TPA, the original spares car for the restoration of TWC. She was missing her entire drivetrain by this point...but I had essentially precisely what I needed to make one working car out of the two by fitting the drivetrain from my original car. We did get a couple of photos of them together back last summer, but TPA was still a fair ways from roadworthy back then.
This was going to be the first time they'd been in one spot while both were roadworthy, so obviously we wanted to get a few photos of them together, have a little drive out in convoy etc.
In preparation for that I wanted to finish off the cosmetic work I'd been doing yesterday. Quick splash of paint first.
Still going to need a little more filler, but a LOT better than it was.
While I had the paint out I gave the fan shroud a quick splash as well. The original paint was flaking off and it was bugging me.
Then gave the interior a quick clean as it was covered in filler dust and rust powder which the heater is still shedding despite my best efforts to clean it out.
Really need to get a wet and dry vacuum on the driver's seat as it is quite grubby (sitting in the back of the garage for two years will do that, not to mention the 200K miles in the donor vehicle).
Soon after I was done with that my guest arrived and we went out for our little drive, stopping at a local from park which has some nice greenery in the background so is a good place to take car photos.
That was quite a fun afternoon. Yes, we did get some properly confused looks when we were out driving in convoy.
Post by Zelandeth » Wed May 15, 2019 12:05 am
Had a pretty full day today so didn't have much time for cars.
One thing which I'm rather paranoid about both in the home and cars is fire. There were a couple of things around the fridge which were bothering me. Simple really in that it chucks out a LOT of heat, especially from the area right by the burner when on gas and around the rectifier/water separator.
The proximity of that to a plywood wall covering polystyrene insulation bothered me. When I first got it the wiring was melted into the water separator too. In addition to fire hazards the fact that the water lines to the kitchen run within a couple of inches of the burner and that makes me uncomfortable.
Some of that is unavoidable to some extent, but I could do something to improve matters a bit with a bit of insulation and rerouting of wiring. I want to do this now as before too long the compartment it lives in will be getting closed in, so there will no longer be a whopping great hole in the wall of the living area. Need to fit a vent in the floor so we can get some decent airflow through the heat exchanger too.
 First up was some foil attached to the wall that's nearest to the hottest areas.
Not pretty but it doesn't have to be... it'll be behind the fridge.
Also wrapped the wiring which has to run up behind it and tethered them to keep them from actually sitting on the water separator.
Will get the gas hooked back up, do a leak and CO escape check then get the thing boxed back in as it should be. Once that's done I can button up the gas locker...once that's done I can do the cupboards. Just need to do stuff in a very specific order for the sake of access.
Post by Zelandeth » Wed May 15, 2019 11:18 pm
Wound up digging around in the locker under the sofa in the van so took the opportunity to install the battery gauge which has been rattling around for months.
The reason I really wanted this installed was because the one in the main control panel appears to have issues. This photo was taken about twenty seconds after the one above.
Hopefully at some point I'll be able to get that sorted. It's a ways down the priority list though.
I had it in my head that there was a local classic car get together here this afternoon...however when I got there it became apparent that I'm utterly useless and had the wrong day - that's actually tomorrow.
So I suddenly found myself with a couple of hours to kill. Figured it was time to throw some more filler at TPA.
Still a bunch more sanding to do, but we're getting somewhere.
Nearside quarter looking almost smooth.
The huge gouges on the nose have been smoothed out. I felt this was quite important given how prominent the area is.
Bonnet hinge area is almost resembling flat again and I've built up the corner of the bonnet which I'd clearly missed on the first pass.
Finally got the hole in the roof filled. Meant the duct tape there can finally go.
This corner is actually starting to look passable. This is as far as I got with the sander. Even with the dust extraction set up the process still makes a godawful mess!
The biggest pits around the rear of the car have been filled, though some further work will definitely be needed there - running out of filler meant I couldn't go much further today!
The chunk taken out of this wheel arch has also been patched up.
Will spend a bit more time with the sander then throw some paint at it. May have a shot at remodelling my original work on the offside front corner first though as the state of that makes my skin crawl...
At least matching the original level of finish on an Invacar isn't too strenuous compared to most vehicles, though even that's horribly time consuming!
Post by Neil Chowney » Thu May 16, 2019 12:36 pm
I'm not posting much but i'm following all your builds with great interest.
It's like project binky with a wheel missing!
Post by Zelandeth » Fri May 17, 2019 12:13 am
Plus an immeasurably smaller budget!
This morning I made an absolutely awful mess in the garage by attacking TP with the sander and some paint. I swear I will be finding filler dust for years...the stuff gets everywhere.
Does look like we're moving in the right direction to me.
The rear could do with a lot more sanding, though I was running out of both time and patience by the time I got there, so it will be revisited of course.
The reason I really wanted to get a basic skim of paint over there this afternoon was that there was a local show this afternoon which I wanted to get TP over to for her public debut at an event other than just driving around. Especially given I arrived yesterday to find I'd got the date wrong.
Did we make it?
Of course we did!
Here's a few snaps of some of the other motors that were there.
I didn't snap anything like every car as I had made a critical wind chill calculation error and was freezing, so the order of the day was brief runs out to snap photos and talk to people between periods hiding in the car waiting for the feeling to return to my fingers.
Plethora of Astons. Not really surprising given the proximity of their factory and that one of the organisers is apparently in the owners club.
Don't recall seeing an MGB in this colour before, I like it.
Normally a BMW wouldn't get a second glance from me (635 excepted), but seeing an i8 up close always feels special. They're still a gorgeous looking car I think.
Oddest coloured car of the day award goes to this Ford Prefect.
Lovely Jowett Javelin. These just look "right" to me, and I only discovered recently that they're really quite interesting mechanically speaking too.
Hard not to like a Scimitar.
I just love the degree of colour in this photo given we live in a world of silver, grey, white and slightly off white cars these days.
While Astons are usually a bit rich for my blood, this thing is lovely.
They really need to bring back tail fins...
There were actually a few Austin 7s there, though this one is a really early example if I'm not mistaken.
I still need to drive an actual Mini at some point!
It would have been downright rude to not take a bunch of photos of this. There's no angle it doesn't look fantastic from.
As usual I never actually took any close-ups of my own car.
Definitely need to make up an information sign to put with the car, as the number of questions I wound up answering was very surprising...and most people didn't even know that they had been rendered illegal and had mostly been scrapped.
Importantly TP ran perfectly both to and from the event, even managing an overtake on the dual carriageway on the way there - cue one very puzzled looking Zafira driver. Afraid I didn't have a camera running at that point to capture that moment...maybe next time (this is why I really need get a proper camera mount so recording video isn't such a pain).
Post by Zelandeth » Fri May 17, 2019 8:08 pm
Given we had a clear weekend we decided it was a good excuse to take the van away for the weekend.
Only an hour from home, but still nice to get away for a bit.
Post by Zelandeth » Sun May 19, 2019 11:06 pm
Sunshine came out for a while today, so got a couple of snaps of our quiet little corner of nowhere.
Back home tomorrow so normal service will be resumed as of tomorrow evening.
Post by Zelandeth » Mon May 20, 2019 8:02 pm
Now safely home. Glad to report the van didn't miss a beat. The relative ease with which 70mph can be obtained for overtaking on the motorway now still surprises me a bit.
Did make one upgrade when I got home. The little 10" TFT TV (fitted I'm guessing around 2000-2005) was essentially useless. The image quality was basically on par with the little screens you get on airliners about 15 years ago, except with even worse contrast. Input was limited to analogue RF, DVD, composite video or an SD card supporting only a handful of mostly obsolete file formats.
It was however attached to a standard VESA mount, which meant I could easily swap it out for something else.
Just like this.
Being somewhat larger than the old one, this protrudes a bit beyond the wardrobe when positioned for viewing in bed...
...It is still able to fold out the way though.
While definitely a luxury item, it is nice to be able to stick a movie on in the background in the evening, so having something able to handle modern video interfaces is a bonus. Even if the TV being used was literally found abandoned at the side of the road with as far as I've been able to tell, absolutely nothing wrong with it aside from being a cheap and nasty piece of tat...more than sufficient for occasional use like this though.
Post by Zelandeth » Tue May 21, 2019 9:33 pm
Have spent most of the day in the garden, and it looks like that will be the case for most of this week. I did manage to sneak away for half an hour in the evening though so thought I'd attack one of the nice simple jobs on the whiteboard in the garage.
At some point the wheels on TPA had been painted with very patchy red oxide primer.
This isn't a good look.
I've decided to go with the same hammered black as I've used for a few other details on the car.
Not a perfect finish by any means, but given there are runs in the paint already on there it's as good as it's going to get for now. At some point (probably in a decade or two) I'll look to get the wheels professionally refurbished. For now this looks better I think.
I doubt that I'll be getting much done this week but hopefully all three wheels will be tidied up shortly. Small details really but bit by bit they add up.
Post by Zelandeth » Wed May 22, 2019 10:04 pm
TPA has been pretty busy today.
Looks much better with the repainted wheels. Here's a better closeup in actual sunlight.
That looks "right" to my eye.
Had a bunch of errands to run today all over town...and decided that the best thing for TPA at the moment really is to get some miles under her wheels...so took a brave pill and took her out. 26 miles covered today once I got back.
This included some trundling around residential areas, some dodging trucks in busy Industrial estates and a fair amount of high speed dual carriageway work. Gremlin count at the end of the day? Nil.
In fact aside from a bit of grumbling from the CVT (belt flapping about a bit because the pulley surfaces still aren't perfect), she was running well and felt well...happy. Not sure how else to describe it. She's far less of a liability on high speed roads than you would expect, the sheer lack of vibration etc through the car at speed is surprising. Honestly she feels less stressed at speed than the Metro I used to own. The ride is also far better than it has any right to be in such a small lightweight car. Even if the slightly odd way the whole car wobbles over some types of road surface simply by virtue of having only three wheels takes a little getting used to. It actually feels like my country wide tour next year might be less of a mental idea than it originally seemed.
Having got a got a few miles of sustained high speed running done today it seemed a good time to check the plugs. When I first started out I had a bit of a recurring issue with the offside plug fouling up with only deposits. My guess was that this was down to a sticky piston ring due to disuse. The oil consumption seemed to have ceased after the first couple of road tests so I was hopeful that the plugs would be looking more healthy now.
Nearside:
Offside (the one which used to suffer from oil fouling):
Those look reasonably healthy to me. No signs of oil anyway, which ties in with no oil being used any more and smoke being limited to a brief puff when the engine is started from cold.
Given I'm going to be wanting to drive out of town to a car show in a couple of weeks it's nice to have got some decent testing undertaken without incident.
Tomorrow I'll hopefully get the cover out and have a close examination of the CVT belt and see how it's holding up. Before I did the work cleaning up the pulleys the belt had been getting well shredded and started to slip after less than ten miles, so will be curious to take a look to see how it's holding up.
Saw a lot of puzzled looking drivers today!
