NIVA FOR SALE - SCARBOROUGH, NORTH YORKSHIRE
Hannesb
Re: NIVA FOR SALE - SCARBOROUGH, NORTH YORKSHIRE
Post by Hannesb » Thu Nov 07, 2013 9:20 pm
Looks nice, but I'm not entirely sure about the "VERY RARE!!" part...
:cry:
1979 Leyland 998 Automatic Mini. Don't ask...
Post by GadgetBoy » Thu Nov 07, 2013 9:27 pm
Me neither. I would say "exceptionally rare."
eosullivan
Post by eosullivan » Fri Nov 08, 2013 1:37 pm
It will be intresting to see will it make the 3000sterling that he hopes to get for it :roll: .Looks to be a nice motor.Eugene
Owner of 5 LADA NIVA's and 1979 Opel kadett Coupe
eosullivan
Post by eosullivan » Sun Nov 17, 2013 2:46 pm
It didn't sell for the expected price of 3000sterling.I wonder wonder will it be relisted again :roll: :roll:Eugene
Marcus
Post by Marcus » Thu Nov 28, 2013 9:06 pm
Hi Folks,
I'm the new owner of the above Niva. Been admiring them for a number of years and finally taken the plunge!
I'm having a few problems and would be grateful if anyone could suggest possible solutions:
Firstly, I've recently changed the rear brake cylinders for new ones (thanks Tom at Lada Spares) as one was leaking and the other seemed inoperative. Bled the brakes but the handbrake is only working on one side.
Secondly, when parked on a slope facing downhill it can take a few attempts to start. Turn ignition key but nothing happens. Seems ok on the flat though. There's also a smell of petrol in the cabin.
Many thanks,
Marcus.
Niva: "It's so overt it's covert"
Niva 1.7i 1996.
www.facebook.com/MarcusCoulterUilleannPipes
Post by GadgetBoy » Thu Nov 28, 2013 9:24 pm
Brakes.
1. Adjust handbrake to 4-5 clicks.
2. In the cabin, engine running, stand on the brakes, no harder than that, for goodness sake man put a bit of effort into it.
3. Adjust handbrake to 4-5 clicks if needed.
That should be it. If the handbrake still doesn't work the rear cable or the wheel mechanism is seized. Remove and lubricate as necessary.
Starting.
Check battery connections, starter motor connections including the spade connector between the two solenoid terminals which is invariably down the side of the spade and not on the spade properly. Check engine earth straps.
Fuel smell.
Replace the vapour separator in the off-side rear quarter behind the plastic trim panel.
If you haven't already download the manuals from my site, link below.
Marcus
Post by Marcus » Thu Nov 28, 2013 9:43 pm
Cheers GadgetBoy! Much appreciated.
Niva 1.7i 1996.
