Lada Spares UK
14 Channel Reach, Channel Road
Blundellsands
L23 6TA
Welcome to the Lada Spares UK Forum
T: 078 7638 7069
E: tom@lada.co.uk
Business hours
Monday - Saturday 10:00am - 7:00pm
Cleaning rust off electrical contacts
Having problems then ask the experts, you'll almost certainly find the answer here.
Postby integraR » Wed Oct 24, 2012 10:18 am
Right I have a new cts on the way but the old one went a bit rusty in the contacts so what I am stuck with is how to remove the rust off those tiny contacts inside the plug, I have seen contact cleaner but none say they will remove rust. It looks like it would be a right epic to get a tiny bit of sand paper in there to clean them out so does anybody have any tips or magic solution to get the rust off? I have rust remover but it turns the metal black and I dont know about the conductivity of the resulting oxadised metal.
Hand painted black niva 96 1.7I aka the problem child!
96 spec Integra type R aka the rice rocket!
integraR
Re: Cleaning rust off electrical contacts
Postby excossack » Wed Oct 24, 2012 10:53 am
Nail file?
John M6JPE
Twitter @vaz21214
Postby GadgetBoy » Wed Oct 24, 2012 12:17 pm
The contacts are rusty because the CTS is leaking. Not worth the effort cleaning it - it'll be stuffed internally.
Sweeper upper
Postby integraR » Wed Oct 24, 2012 4:26 pm
Its the plug not the cts I have a issue with, its the cts plug/socket onto the loom that has a little rust on the terminals. Should I cut the plug off and bodge with a couple of connectors when the new one arrives?
integraR
Postby GadgetBoy » Wed Oct 24, 2012 5:10 pm
No. Absolutely not.
Clean as best you can with a needle file.
Sweeper upper
Postby Zelandeth » Wed Oct 24, 2012 7:43 pm
Stick a bit of chunky electrical flex into a drill, having stripped about 20-25mm of wire at the end, insert wire into the socket, then run the drill. It'll clean the contacts up nicely.
Current fleet: 1989 Saab 900i, 2009 Peugeot 107 Verve, 1987 Skoda 120LX, 1980 VW T25 Transporter Camper Van, Sinclair C5.
Return to Technical Support
Who is online
Users browsing this forum: No registered users and 1 guest
